Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 11th November 2016, 08:21 PM
Albert_Swafega Albert_Swafega is offline
Default Here we go again..........Heater Woes
Well, it's that time of year, and you expect the heater to work?
Nope, took a ride today, and the only heat was off the heated seats.
Took a scan, and found:
Address 08: Auto HVAC Labels: 4H0-820-043.clb
Control Module Part Number: 4H0 820 043 D HW: 4H0 820 043 D
Component and/or Version: Klima 3 Zonen H14 0061
Software Coding: 3621002800
Work Shop Code: WSC 02313 785 00200
ASAM Dataset: EV_AirCondiFront 001050 (AU64)
ROD: EV_AirCondiFront_AU64.rod
VCID: 21503B5361C9138A302EBB9-8075
1 Fault Found:
0378 - Coolant Circulation Pump
B10D0 04 [009] - Internal System Fault
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 217
Mileage: 175128 km
Date: 2016.11.11
Time: 21:03:57
Has anyone seen this before? is there a circulation pump just for the blowers? Where is it? Are they easy to change?
2011 A8 Executive 3.0 TDI Quattro
Old 11th November 2016, 08:35 PM
Joe2.0E Joe2.0E is offline
Not had an issue with heat but there has been issues with electric coolant pumps.
See D4 - Common Faults - Wiring Loom Issues.
Old 11th November 2016, 08:46 PM
Cheers Joe,
searched "0378 - Coolant Circulation Pump" to no avail.
strange...it was there all along?
Old 11th November 2016, 08:47 PM
Sounds depressingly similar to the Auxiliary Coolant Pump that afflicts D2s and I think D3s to a lesser extent.
Old 11th November 2016, 08:57 PM
Yes, I had this on my car - was repaired under warranty so no idea of cost - but I don't think it was a huge job! Good luck.
Old 11th November 2016, 09:01 PM
Take a look at this thread - maybe helpful
http://forum.a8parts.co.uk/showthread.php?t=11613
Old 11th November 2016, 09:17 PM
were the blowers cold too Paul?
