Old 18th February 2017, 09:53 PM
Red face Clarification of 'Chassis No' for Parts
Probably a daft question, but just need confirmation before I spend some money.
Was looking at some suspension parts and it says on them 'Chassis no to 4D-X-005 500'. There are also similar ones that say 'Chassis no from 4D-X-005 500'.
Does this come from the VIN number of the car, with it being the relevant last six digits, or what? My VIN is WAUZZZ4D92N002072.
Old 19th February 2017, 05:39 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
I've had similar issues when ordering bits for the rebuild.
Always just worked on the last 4 digits - never had a problem
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 19th February 2017, 06:56 AM
My understanding is that X is important as well as it is model year where X stand for 1999.
For example my VIN is WAUZZZ 4D Z W N 002603 with relevant bits in bold. So I am looking at W first, as it is before X in alphabet I know it falls in up to X-005550 category, if I had Y, 1 or 2 I would know it falls in after category, I would only look at numbers if it had X as the letter. You can ignore the N in the middle as it is the factory where it was made, N is for Neckarsulm, Germany. The W in mine shows that it is 1998 model although it was actually manufactured late in 1997.
Old 19th February 2017, 11:23 AM
Cheers fellas.
It appears mine then fails in both scenarios
I'm quite surprised by how much the front suspension changed. The kit I need is apparently this one and the one I was eying up is this one
I was thinking that if I changed the whole lot it would be okay, but from the pictures alone, there are significant changes to the design. Maybe I should take a wheel off and see exactly what type I've got, just to be sure, to be sure.
Old 19th February 2017, 12:29 PM
Yours is the 'Chassis no from 4D-X-005 500' set because your is model year 2: WAUZZZ4D92N002072. The actual number becomes irrelevant at that point.
The only difference between those two kits is the size of the tapered pin on the lower front arm (check the 'Details' tab). They have photographed some of the arms as a mirror image in the two different kits which makes them look different when they aren't.
The steel uprights (PF, and FL with 20s) have the large pin (Meyle kit 116 050 0030/HD with lower arm 116 050 8228/HD) and the alloy uprights (FL) have the small pin (Meyle kit 116 050 0041/HD with lower arm 116 050 0031/HD). A 2001 will have alloy uprights so you need the latter
Old 19th February 2017, 01:39 PM
Cheers MJ.
That's cleared that confusion up for me.
Now I must go and lie down as my bank account has just suffered an abnormal liberation of funds.
