Old 3rd April 2017, 02:17 PM
Default Removal of Fuse Box in Drivers Footwell
Has anyone removed the fusebox in the drivers footwell to get access to the wiring behind it? I've had a look and it only appears to be held in by two bolts. Just wondering if there is anything else I should be aware of before I break something. Also wondering how much leeway there is with the cabling to allow movement.
Old 3rd April 2017, 09:25 PM
big t5 big t5 is offline
I haven't removed it but have taken out the two bolts and pulled out the fusebox to hard wire a few accessories. There wasn't a lot of leeway but you can get behind it. Hope this little info helps.
