Go Back   A8 Parts Forum > A8 D4 > D4 - Wheels and Tyres
D4 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here
Old 31st October 2017, 09:27 AM
richardracer richardracer is offline
Default D3 wheels fit on a D4?
Hello forum experts,
Would D3 S8 wheels fit on a D4 A8? Somewhere deep in my memory cells is something about the bore of the hub being different?
If anyone has the dimensions of offset and hub bore size, could they let me know.
Thanks
Richardracer
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 31st October 2017, 09:37 AM
This should help
https://www.wheel-size.com/size/audi/a8/
Old 31st October 2017, 09:47 AM
Yup.. The newer ones are 66mm and the older ones are 57mm. Pretty sure the D4 is the new size, and D3 the old one.
Old 31st October 2017, 09:58 AM
You are correct. Options would be bore out the wheels, buy spacers/adaptors or just get another wheel - I chose the latter for my winter rims
Old 31st October 2017, 10:03 AM
Spacers could be a good option as you'll need them because the D3 wheel offset are around ET45 and the D4 usually around ET35. So 10-15mm spacer that goes from 66 > 57 bore is the ideal adapter. Easily machined if there isn't an off the shelf item.
Matt
Old 31st October 2017, 07:02 PM
Default D3wheels on D4
Hi folks,
Thank you for your responses. The answer is no, unless you change bore diameter.
Regards
Richard
