D4 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
Hello forum experts,
Would D3 S8 wheels fit on a D4 A8? Somewhere deep in my memory cells is something about the bore of the hub being different? If anyone has the dimensions of offset and hub bore size, could they let me know. Thanks Richardracer
Yup.. The newer ones are 66mm and the older ones are 57mm. Pretty sure the D4 is the new size, and D3 the old one.
You are correct. Options would be bore out the wheels, buy spacers/adaptors or just get another wheel - I chose the latter for my winter rims
Spacers could be a good option as you'll need them because the D3 wheel offset are around ET45 and the D4 usually around ET35. So 10-15mm spacer that goes from 66 > 57 bore is the ideal adapter. Easily machined if there isn't an off the shelf item.
Hi folks,
Thank you for your responses. The answer is no, unless you change bore diameter. Regards Richard
