So after changing the brake fluid myself the other day, with help from those here, I took the car for the MOT two days ago. It passed with no Advisories at all, so must have done the brakes properly, but I have a question.
It wasn't until much later in the evening/night that I realised that the tester did not follow procedure and test everything that he should have. Now he was a decent enough bloke and asked about the car, and I had no reason to complain about him, but I'm of the opinion that I should raise a complaint. Now I suspect that there may be those out there that might say I was lucky that he didn't check everything, but that's not the point. I'd rather find out that my front wheel is about to fall off and have the car fail the MOT, than find out about it the hard way. I don't know the MOT procedure in the rest of the UK, but in NI, it's all done by a government body, and is split into three sections in the building. The first section deals with visual checks of parts around the car, inside and out, the second section deals with brake and suspension effectiveness and the last is a visual inspection underneath the car. That's broadly speaking. Everything that the tester missed was in the first section (while I was in the car). He never checked the ESP/ABS and traction control, wipers, windscreen washers, windscreen, horn, spare wheel or seat belts. The majority of these I check myself anyway, except the seat belts (I never have), so I know they're working. I hate it if the car fails the MOT because a single brake light or single indicator didn't work on the day (like last year with my nephews Defender), but set belts are a different kettle of fish. I could get into 'what ifs', and of course the MOT is only a 'snapshot' in time, but it is a concern. So, what say you?
Sounds like your more conscientious than the test centre, so I'd leave it. Seat beats are highly unlikely to be faulty, but maybe I'm a bit more of a risk taker than some on here...
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. Last edited by tintin; 14th April 2018 at 12:21 PM. |
Well done Sean on the bleeding brake job. Sorry, it was the Leprechaun that made me mix the words up.
![]() ![]() ![]() I lean towards Steve's (Tintin) reasoning. You do your daily checks very well and you know as well as if not better than any tester when your front wheel is about to fall off. Basically, not worth the paper work, unless you are the tester tester ![]() Many years ago, about 1959, I was rushing to catch a ferry of Dover. Travelling from Folkestone down Dover Hill my rear nearside wheel came adrift but stayed within the wheel arch. I'd had the tyre repaired the day before. Luckily the wheel nuts stayed in the hub cap and no damage done. Refitted the wheel and continued on my way to Germany. Made a memo to self, always check other peoples work.
Seatbelt check is simple to do if you're concerned. 1st... Pull the belt out as far as it will extend, visually check the condition of the webbing for wear and cuts and then retract. 2nd... Pull out again and this time with a fast short sharp tug the belt should not be able to be pulled out, it should stop dead and the belt holds steady. 3rd... put seatbelt buckle into holder and ensure it holds and unclips properly
Job jobbed ![]()
. Nite Blue 3.0L SE Quattro |
Not concerned about testing the seatbelt, more the fact that these people are employed to check these things and he didn't bother. Suppose there was a fault with the locking mechanism and the car was involved in a head on smash. Can't really just say 'whoops' to a grieving parent!
I would agree with the comments on here - an MOT (whether is is the govt based system we have here in NI or a local garage in the UK) is a snapshot of a vehicles road-worthiness at that minute in time.
It is done by one person. That person may not remember all his/her training, may not remember everything that has to be done etc. May be under pressure if the last MOT took to long etc etc. I've put countless cars/vans/trucks through an MOT/PSV over here and I've noticed that sometimes one or two items will be missed. Not checked horn on one test, could be fog lights on the next. Generally though everything is covered and you have paperwork to prove it's road worthiness. At it's last MOT the examiner picked up on a knackered bush which was causing shudder in the S8 at 70mph. Tyre garage and mechanic were both convinced it was a buckled rim - eagle eyed examiner found a split bush and yet another bodged job by the previous garage. For this I do have to thank Mallusk MOT centre ![]()
Daily drive: 2016 Infiniti QX70.....a car that's even more complicated than my last Infiniti FX to modify ![]() Current 'Project': VW Crafter CR50 4 berth camper van Previous 'Projects': 2006 Subaru Legacy Spec 'B' 3.0R, 1994 Ex-MOD Land Rover Defender, now "civilianised". 2000 Audi S8 FL www.whall.co.uk |
