Could someone please take off the cover and post some photos of the routing of the washer pipes as they leave the wing, pass by the wiper motor and join the scuttle cover. Ideally from a car where it is all laid out correctly.
![]() Mine is very untidy and taut, so taut in fact that one of the pipe joints came apart recently, though a bigger cable tie fixed that for now. I seem to have a shiny black (looks reinforced?) pipe that comes out of the wing (from the washer fluid tank/pump) then joins to a small grey unit (non-return valve?) then a 90-degree rubber elbow (by the wiper motor) onto the hard black plastic pipe along the scuttle cover. I also have cable ties holding the pipes and heated washer jet cables in what appears to me to be non-standard places. When my fan jet washers arrive I intend to tidy up the whole thing. A good reference to work to is what I'm after. Thanks in anticipation. ![]()
Mine seems pretty tidy and not "buggered" around. Not much to see to be truthful but hope these help, Andrew.
Thanks for that David, mine's surprisingly similar but just lacking in length so tight.
I even have the same cable ties in the same places, though they don't look right to me.
My pipes are all very tight up there as well. Seems normal. I’ve had a couple of pipe blow-offs that have necessitated cable ties at joints as well. Usually when the nozzles get blocked, and the joints can’t deal with the extra pressure. All the pipes are specific lengths....they have a little ballooned bit at each joint to hold the rubber 90 and t pieces on more effectively.
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
![]() I had the whole scuttle off a while back so have obviously been negligent when putting it back together. ![]()
I still have had the same problems as you Andrew, as the pipes from the right angled section onward are cut to the extreme minimum, and I've had one come off. No point in me taking a photo of the pipes and wiring, as I've had to take mine off to get at the passenger washer. Hadn't filled the water tank, and then one day driving through a long section of roadworks with muck everywhere, was using them almost continuously, and sucked it dry. Passenger washer completely gummed up with what someone referred to elsewhere as 'snot'. Took off the pipe and then spent about 15 minutes with hot soapy water and a 5ml syringe to clear it.
