Well, I bought another one
![]() ![]() £600 later, I had this: A one-owner 3.7 quattro, with sport seats (not a Sport model mind). It was bought new at Exeter Audi as a company car, and then at the end of its company service was bought from the company by it's driver and kept by him until about six months ago when the gearbox failed at 117K. It appears to have had the same private plate from new until it was disposed of. I could tell as soon as I opened the door it had suffered some serious water ingress - it smells like a locker room and there is mould all over the place. Still, a decent haul of parts for the money. At least, that was the plan ![]() I got VCDS on it to read the gearbox codes and see just how exploded it was, and curiously there were no 'incorrect ratio' codes normally associated with a blown 5HP19, just loads and loads of sensor and solenoid failures. The ECU was the same - it had three pages of codes ![]() ![]() All the ECU codes cleared fine, as did a couple of TCU codes once I'd cleaned up all the body harness connectors. I had a spare FL ESP unit so I just swapped and recoded that, and that was also fine. I didn't have a spare TCU of the right code though, so pulled that out and opened it up... Oh dear! Still, I had some time so I got out the isopropyl alcohol and a toothbrush and got scrubbing. After an hour of it sitting on a hot radiator I put it back in. Result! ![]() ![]() To celebrate, I gave him a bath and named him General Vod ![]() Only two minor bits of body damage Of course now he's working and has a name, he can't be a parts car any more can he? ![]() Last edited by Architex_mA8tey; 12th January 2020 at 09:57 AM. Reason: OP request |
Well that has to be the shortest "What's in the workshop this weekend?" thread ever, but great to see another D2 saved from the crusher.
I'm not finished yet
Amazing how some people just simply can't be bothered to find out what is wrong. When there is obvious water ingress then it is highly likely to cause issues. Having said that, it gives opportunities for others (MJ) to buy them cheap with an 'easy' fix.
Well done MJ, you deserve some easy ones, although as you have said, 'this one isn't finished yet'!
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
The crazy thing is that it's already had a gearbox rebuild at some point! I guess it must have been out of warranty so when it started having problems again they just bailed on it rather than investigating.
This is my hit list prior to MoT on Tuesday: Not on the list is 'remove swimming pool from driver's side carpet' and valet the interior so it doesn't smell of old socks ![]() |
Good work and it’s just so important to keep as many good D2s on the road
-- 2001 Audi A2 1.4 SE - Jaipur Red Pearl -- |
ps ...maybe ~I should look under the driver side carpet Last edited by oldnick; 24th April 2019 at 11:13 AM. |
