Hello all, I have a weird probblem with my 2003 A8 4.0 tdi which I wondered if anyone could advise on?
Most times when I start the car, especially if it has been sitting overnight, the car starts fine but the dash cluster goes black (as does the button illumination through the MMI unit etc) and after a few seconds the dials come back on bu the time has reset to midnight and the date to Feb 2003. This is sometimes accompanied by other warning lights (EML light, traction control, ABS etc) and sometimes not. I have VCDS and have scanned it which has given the following results - however I've only just got my copy of VCDS so not very clued up on deciphering the results - can anyone assist? Thursday,26,December,2019,21:53:33:04536 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4 Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: WAUZZZ4E24N007142 License Plate: Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 72 76 VIN: WAUZZZ4E24N007142 Mileage: 157280km-97729miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 409 C HW: 4E0 907 409 B Component: 4.0L 4V/TDI G000AGMª0020 Revision: <> Serial number: AUX3Z0C6120358 Coding: 0010773 Shop #: WSC 02313 785 00200 VCID: 2313E8E3E7D4E39FF45-8076 1 Fault Found: 18058 - Powertrain Data Bus P1650 - 002 - Missing Message from Instrument Cluster - Intermittent Freeze Frame: RPM: 630 /min Torque: 128.7 Nm Speed: 0.0 km/h Voltage: 13.53 V Temperature: 38.7°C Bin. Bits: 00000000 Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 J HW: 09E 927 156 A Component: AG6 09E 4,0LTDI RdW 0040 Revision: 00000001 Serial number: 0017213 Coding: 0000001 Shop #: WSC 00183 210 58462 VCID: 290FFACB85F839CFBE9-807C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 A Component: ESP 5.7 allrad H29 0420 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 211FE2EBFDC8F18FE69-8074 2 Faults Found: 02257 - Remote Control Receiver 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 203 Mileage: 157282 km Time Indication: 0 Date: 2003.02.27 Time: 01:42:37 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 243 Mileage: 157282 km Time Indication: 0 Date: 2003.02.27 Time: 00:00:35 Freeze Frame: Bin. Bits: 01 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 Component: KLIMAAUTOMAT 015 0240 Revision: 00000018 Serial number: 00000000020954 Coding: 1071105 Shop #: WSC 02311 785 00200 VCID: 5AED9507901E6257E73-800E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.clb Part No SW: 4E0 910 279 E HW: 4E0 907 279 E Component: ILM Fahrer H11 0100 Coding: 0010001 Shop #: WSC 02311 785 00200 VCID: 2A0D05C780FE32D7B73-807E Subsystem 1 - Part No: 4E2 910 113 Component: Wischer WWS D3 H30 0320 Coding: 00000030 Shop #: WSC 02311 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E0 910 409 C HW: 4E0 907 409 B Component: 4.0L 4V/TDI G000AGSª0020 Revision: <> Serial number: AUX3Z0C6120358 Coding: 0010773 Shop #: WSC 02313 785 00200 VCID: 2313E8E3E7D4E39FF45-8076 1 Fault Found: 18058 - Powertrain Data Bus P1650 - 002 - Missing Message from Instrument Cluster - Intermittent Freeze Frame: RPM: 630 /min Torque: 128.7 Nm Speed: 0.0 km/h Voltage: 13.53 V Temperature: 38.7°C Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 Component: Airbag 8.4E+ H09 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 6393A8E3A754A39FB45-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H09 0030 Coding: 0112041 Shop #: WSC 02311 785 00200 VCID: 6597B6FBA960DDAF5A1-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0050 2 Faults Found: 02441 - Yellow Malfunction Lamp in Instrument Cluster 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 203 Time Indication: 0 Date: 2003.02.27 Time: 01:42:59 Freeze Frame: Voltage: 10.56 V Reset counter: 243 Mileage: 157288 km Time Indication: 0 Date: 2003.02.27 Time: 01:42:59 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 HW: 4E0 919 283 A Component: Parkhilfe 8-Kan H07 0030 Coding: 0001008 Shop #: WSC 02313 785 00200 VCID: 6099A7EFB642B887A97-8034 No fault code found. End----------(Elapsed Time: 01:59, VBatt start/end: 14.1V/14.3V)----------- |
RPM: 630 /min
Voltage: 13.53 V Does it idle at 630rpm, or is that the cranking speed during starting? It looks like there are missing CANBUS messages at this time the codes are set - some of the messages are telling dash illumination to come on etc... If this happens again, can you manually turn the healights on and off a few times with pauses in between as this will send the illumination messages again. I would think a low battery would cause this but the freeze frame voltage shown is good, but was this voltage perhaps after the engine started (630rpm) |
The first thing I'd suggest you do is clear all the codes, as some date back to 2003. Once cleared, go for a drive (leave overnight if necessary to reproduce symptoms) and then scan again. Post that scan and go from there.
With regards to the current scan, I'd say it's possible a faulty connection on the instrument cluster, or, since both engine and ABS modules are throwing errors, then (if the same errors reappear), check the physical connections to these ECUs for water ingress, both of which are in the plenum chamber, and open to the elements. Also pop along to the Introductions page and introduce yourself. We also have an affinity for photos, so brownie points on offer there.
