I've had this unusual occurence... Driving on the motorway, the Ambiental lights in the door cards - the long ones just stopped working, than in few seonds came back again. Than again in few minutes they're off for good. And I don't know what to do to turn them on again. Every other option in the Background lighting works (City, Back, Front) only "Highway" lights on the door cards does not work. Where should I start looking for the solution? I have VCDS...
S8 D3 FL II. Porsche Cayenne 958 Turbo BMW E83 X3 3.0d M-Sport |
Update:
Sometimes when I come to my car and unlock it, the complete ambiental illumination on the door cards work, but turns off in about three seconds ![]() No codes, nothing!!
When you say you've no codes, do you mean there are no error codes for any of the four doors (since each door has its own control unit) or no error codes at all for the car?
It seems rather odd that all four door control units would get the same problem at the same time, and since you also mention that they intermittently work, I'd suspect another control unit. Specifically, the sunroof electronics control unit (J528) as that is where the ambient light data is stored. Using VCDS, check address 38 for possible errors. Even if there are none, I'd be inclined to remove the sunroof unit and check the electrical connections to ensure they're all seated correctly, and then check to see if there is any moisture or corrosion in the contacts. The final item I'd check would be the lighting profile button in front of the sunroof rotary knob (between the reading light buttons) to see if it was working correctly and wasn't sticking in position, as you can use that to alter the light intensity. Check out the following SSP found on the D3 Tech Dump thread for more information (from page 68): 53-SSP 287 Audi A8 03 - Electrical Components
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
