Old 11th January 2022, 08:48 AM
rory_pamphilon's Avatar
rory_pamphilon rory_pamphilon is offline
Default Key Fob remote lock/unlock stopped working.
Hi,
For some reason my car has decided to suddenly not pay any attention to either key fobs. Both fobs have had recent battery changes and both show the green light on the key when i press a button.
However the car wont lock or unlock when standing right next to it pressing buttons on either keys. Im having to unlock and lock the doors by manually inserting the key at the moment.
It starts and drives fine once the key is in the ignition. I have the keyless start stop also and when i press that with no key in the ignition it says "key not found".
What is the difinitive method for resetting the key fobs for the D3? i have seen so many different methods online.
Thanks
Old 11th January 2022, 10:29 AM
homer simpson's Avatar
The lock/unlock feature is completely different to starting the car. The car starts, so the authorization works. Try putting the key near the steering column and see if the start button works.
Ideally you want a scanner on the car to see what codes it is throwing up. Also check that the passenger footwells are dry
Old 14th January 2022, 09:18 AM
Thanks for the reply.
It has however just fixed itself, i think perhaps the battery was running a little low and maybe it disabled the central locking during that period. I saw v brief yellow low battery flash up a few days ago. Ive since been on a few runs and its all back to normal now.
Old 10th May 2022, 01:56 PM
kele kele is offline
On a tangent somewhat.. I have bought an identical 3rd / spare key for my S8. Although new condition and new to me, it has been used and is programmed to work with another car. I was hoping I could clone one of my other keys that works with my car today. Is that possible?
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 10th May 2022, 05:55 PM
You could try contacting Craig Nettleton of Auto Solutions. He has a Facebook page, but can also be contacted on 07900600548 or via email at craigynett@gmail.com
https://www.facebook.com/groups/270275792987687/
Old 10th May 2022, 09:42 PM
You cannot clone a key, well theoretically you could but it has fixed ID and variable code which changes every time it's used. So if you used new cloned key the variable code would change on the cloned key when you use it but would stay the same on old key so old key would not work. You need to pair each key individually. It's possible to pair old key but I think you need the immo box or dash from the donor car as well. Easier to get a new ID44 immobilizer chip and change it donor key, then program as new key.
This is for coding the key to start the engine, remote control part to lock unlock doors you can pair yourself.
