I have a left hand drive D3. When I operate the climate controls, they are reversed on the screen. ie, I operate the passenger side fan speed, seat ventilation or heating it says driver's side but it does indeed work for the passenger side. Can this be recoded with Ross Tech VCDS? It's not crucial this get done, but it annoys me a bit.
Check out the following thread which describes your exact scenario:
https://www.a5oc.com/threads/climate...eversed.25972/ Here is the relevant section about the MMI hidden menu: You can test this by holding down the 'Setup' button on the console, then whilst continuing to hold it, press the 'Car' button for 5 seconds or so. If nothing changes on the MMI screen, it's not enabled. If however the sequence above brings up a green screen with some unfamiliar (and largely German) options lists, then you may be in luck. You should see a 'Diag settings' option - select this and then you'll see further options in German including 'Car Menus Maske'. Click that and you'll see some interesting stuff like Battery level and, relevant to your particular question, 'Linslenker'. Checking/unchecking the Linslenker option will essentially reverse the relevant control functions left-right (and vice versa) to cater for left-hand drive/right-hand drive cars. If the green menu isn't enabled, you can do so using VCDS with the following instructions. NB: You need to be on version 5570 of the MMI:
I had a similar issue after the main dealer replaced the climate controls on my Q7, long story short, they hadn't been coded correctly and were at least partly coded for LHD in a RHD car. If you have VCDS, I'd suggest checking the coding
I do not have the green menus and cannot figure out how to turn them on. I have HEX-NET and an Android tablet but can't seem to figure out how to do this. I've never really used it except for viewing and clearing codes. Do I require a PC and the software to be able to do this? Thanks Last edited by AlHeart; 26th August 2022 at 06:23 PM. Reason: Xx |
http://wiki.ross-tech.com/wiki/index.php/Functions
How can I upgrade the MMI software version? Amy other ideas? Last edited by AlHeart; 31st August 2022 at 04:22 AM. |
Check out the following page for full instructions:
http://mr-fix.info/mmi-2g-software-update-version-5570/
