Go Back   A8 Parts Forum > A8 D4 > D4 - Engine Bay
D4 - Engine Bay Everything under the bonnet
Old 2nd November 2022, 09:41 AM
Saff Saff is offline
Default A couple of Nube questions
Hi, I'm sure there will be plenty of questions coming your way in the future
4.2 TDI, I'm assuming its chain and not belt for the valve timing?
Also, I try to do my own basic servicing so: I understand that the oil filter is on top and changeable from under the bonnet, as I always used a Pela suction pump through the dipstic tube on my E-Class (remove plug as no dipstick fitted) is there a removable plug on the dipstick tube 'stump' on the V8 TDI to enable me to do this?
Thanks for your advice, Steve
Old 2nd November 2022, 10:02 AM
If you haven't already found it, check out the following thread in the D4 section. It's under 'A8 D4' > 'D4 - Common Faults':
D4 - Technical Info & Upgrades Sticky
Old 2nd November 2022, 11:58 AM
Hi Steamship and thanks. I've had a look at this and its very technical. I'm struggling to find reference to the dipstick tube/plug on here.
Old 2nd November 2022, 02:59 PM
In regards to the 4.2tdi engine, I can only find one reference to the dipstick in the following PDF:
10-Service Manual 8-cylinder TDI engine (4 2 ltr 4-valve common rail).pdf
You'll find it in section '19 - Cooling' in sub-section 3 (p.249). The PDF shows it with an actual dipstick, but the official parts catalogue shows it as only having a plug (part #26 comes up as 'not for this model'). The fact that it has an o-ring would imply that you can remove the plug.
Name:	Audi A8 D4 4.2tdi dipstick stud.png
Old 2nd November 2022, 03:35 PM
Thanks Steamship. As long as I can get the oil extractor tube in there. I always do a 'top' service where possible, getting a bit creaky to maul about underneath.
Old 2nd November 2022, 04:47 PM
You can, I also adapted a dipstick to work with my D4 4.2tdi as easier than the computer in my mind - from memory, I used an old one from a b6 S4 that I had lying around and added a twist in my vice for the upper and lower levels based on the MMI read out
