Old 10th February 2023, 01:12 PM
danyalmakda danyalmakda is offline
Default Shocks
How do I know if I have sports or comfort shock absorbers
The rear ones are defo red not sure on the fronts
The previous owner replaced all four springs so thought might change shocks as getting quite rusty
Thanks
2002 Audi A8 D2 3.7 Quattro AquaBlue
Old 10th February 2023, 04:43 PM
No point in reinventing the wheel, so check out the following post. It gives the relevant PR codes, colours and even part numbers:
http://forum.a8parts.co.uk/showpost....19&postcount=4
Old 10th February 2023, 05:41 PM
Thanks
Thats just confused me even more - am I correct as in those those are just for springs?
I’ve just checked the invoices and the old man changed all for with eibach pro springs
So I was just wanting to check which shocks I should replace them with
Bilstein is way to expensive
The rear shocks of mine are red so assuming they are sports shocks?
Was looking at sachs but was not sure if they were the right ones for replacements for my car
Thanks in advance
Old 10th February 2023, 06:33 PM
Yep, that's just the springs.
In terms of using aftermarket ones, there are others on the forum who have changed theirs, and are more knowledgeable as to what to go for.
As for your rear shocks being red, I believe that's the colour they were originally painted, although MikkiJayne can clarify.
Old 10th February 2023, 07:44 PM
Red does denote sport shocks. Fronts should be the same. Unfortunately there aren't any aftermarket direct replacements for the sports ones, only the standard models which will lift a sport a few cm. If its just a matter of cosmetics (and they last well over 100K in terms of damping) get the originals media blasted, paint with red oxide primer and satin clearcoat and they usually come out looking original.
I've found Bilstein B6 are really only suitable for 20" wheels. They're too hard for 18s and just make the car bouncy and unpleasant, and very expensive.
Old 10th February 2023, 07:58 PM
Interesting and timely (for me) comment. Last night we were having a "pub discussion" about how often people needed new shock absorbers on older cars. I commented that it's never been an issue on A8/S8 that I was aware of and in fact it appeared that the shock absorbers generally outlived the car! Looks to be not far from the truth!
Old 10th February 2023, 08:36 PM
Thanks
Will just need to find someone who can do that in Leicester
