Old 26th March 2023, 10:15 AM
jonnypym123 jonnypym123 is offline
Default Front undertray retaining clips
Does anyone know what 3 retaining clips are underneath the engine undertray, are these the right ones?
https://www.ebay.co.uk/itm/324177085...mis&media=COPY
I've got the undertray held up on cable ties at the moment so once I get them off I want to make sure I have the right clips.
Old 27th March 2023, 09:26 PM
The last time I had the front undertrays off on a D3, there were nine grip pins (3B0805121) and nine rubber washers (4A0805137). From memory, the grip pins screw into metal fixings. Perhaps someone with a D3 can confirm before you buy them.
Name:	A8 D3 Grip Pin.png
ID:	29417   Click image for larger version
Name:	A8 D3 Rubber Washer.png
Old 23rd April 2023, 03:14 PM
AlHeart AlHeart is offline
The above two parts posted by steamship are correct. You might also want the part that clips on the bracket and holds the screw. Part, 8D0805960.
Old 19th May 2023, 09:46 PM
monkeyboyuk monkeyboyuk is offline
Isn’t there a metal retaining bar of sorts where the front of tray meets the front bumper, and some additional fixings along back edge of undertray….. just remembering of this from when mines fell off
2021 Q7 4M, 3.0tfsi MHEV Black Edition
2002 D2 S8, Aqua Blue Pearl, original bar FE alloys and miltek
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. ** FOR SALE **
1990 2.3 20v 7a Coupe Quattro
**SOLD** 1996 2.6 v6 cabriolet, Isis red metallic
**SOLD** 2014 D4, FL 3.0tdi, phantom black, sport exec lwb
**DEAD ** 2009 D3, 3.0tdi sport, black
Had a few Audis over the years, mostly early stuff, newest was a D3 prior to my D4, nothing much kept me smitten with other marques so I floated about a bit from one thing to another until that four ring lure caught hold
Old 20th May 2023, 10:27 AM
There is a metal bar that helps support where the two undertrays meet. #7 in the attached image. That is where the metal clips that AlHeart mentioned go.
Name:	A8 D3 Front Undertrays.png
Old 20th May 2023, 11:28 AM
I could have swore mines had another bar where the larger tray section joined the bumper at front, mines randomly fell off, well was hanging off and scraping ground…. Then before I managed to get it home to jack it n fix it it had fallen off, with the undertray then hanging n scraping. Regardless of how many times cable tied it it kept falling off again, and tearing the wheel arch liner. In the end it was barely hanging on at back where it meets the other one and I took it off completely
