D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out |
So as some of you may know I’m now a fairly happy owner of a d4 to replace my beloved, but written off, d3 (rip)
However, I’ve had a few issues, some of which are ongoing, but the dealers been great so far in trying to get things resolved. 1/ regularly drops into limp mode - this now seems to have been resolved with a new turbo (under 80k miles) 2/ air con pump, error flagged in vcds 3/ auto stop start, error in vcds and I’ve been experiencing regular issues when trying to use. Ie getting stranded at a busy junction, having to totally ‘reboot’ the car 4/ suspension - no errors but it feels every bump n ripple in roads you could imagine - nothing like as comfy or smooth as my d3 5/ phone antenna 6/ lighting to rear n/s door The dealer doesn’t have their own mechs but use someone else who I’ve not been enthused by…. They’ve not managed to resolve any of these issues other than the turbo one, apparently they can’t find faults Yet, every time I scan they appear so there’s something there to investigate…. Any how’s, thought I’d share with you, including one of the early scans pre turbo being resolved, to see if anyone had any knowledgeable input to share on any of the errors I’ve agreed with the dealer to take it to my local Indy for investigations so will hopefully get to bottom of things Tia for any input
2021 Q7 4M, 3.0tfsi MHEV Black Edition 2002 D2 S8, Aqua Blue Pearl, original bar FE alloys and miltek 1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. ** FOR SALE ** 1990 2.3 20v 7a Coupe Quattro **SOLD** 1996 2.6 v6 cabriolet, Isis red metallic **SOLD** 2014 D4, FL 3.0tdi, phantom black, sport exec lwb **DEAD ![]() Had a few Audis over the years, mostly early stuff, newest was a D3 prior to my D4, nothing much kept me smitten with other marques so I floated about a bit from one thing to another until that four ring lure caught hold |
![]() Code:
Wednesday,17,May,2023,18:56:03:61808 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 23.3.1.0 (x64) Data version: 20230421 DS346.2 www.Ross-Tech.com VIN: WAUZZZ4H6EN011996 License Plate: CV14FXC Mileage: 129579km-80516mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4H-AU64 (4H0) Scan: 01 02 03 05 06 08 09 15 16 17 19 28 30 34 36 3B 42 44 46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 85 88 89 8F 90 AC VIN: WAUZZZ4H6EN011996 Mileage: 129579km-80516miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 30-Special Function II -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 3B-Sensor Elect. -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 81-Gear Shift -- Status: OK 0000 85-On Board Cam. -- Status: OK 0000 88-Multicont. Seat Driver -- Status: OK 0000 89-Multicont. Seat Pass. -- Status: OK 0000 8F-Pretens. Frt Left -- Status: OK 0000 90-Pretens. Frt Right -- Status: OK 0000 AC-Reductant Control -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CTBA) Labels:. 059-907-401-V2.clb Part No SW: 4H0 997 401 E HW: 4G0 907 401 E Component: 3.0TDI EDC17 X14 0002 Revision: 58X14--- CVN: 14D79D530000000038D3FF82 Coding: 0A2A4032052601030800 Shop #: WSC 65535 000 00000 ASAM Dataset: EV_ECM30TDI0114H0997401E 001002 ROD: EV_ECM30TDI0114H0997401E.rod VCID: 2F6D7D8B76EC3CEB62-807A VINID: 9D196AAAA1181957800412491801BC4F75 1 Fault Found: 5171 - Boost Pressure Regulation P0299 00 [096] - Control Range Not Reached Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 129173 km Date: 2023.05.16 Time: 14:19:28 Engine RPM: 1873.00 /min Normed load value: 87.1 % Vehicle speed: 137 km/h Coolant temperature: 96 °C Intake air temperature: 23 °C Ambient air pressure: 1020 mbar Voltage terminal 30: 14.120 V Unlearning counter according OBD: 37 Charge Pressure Actuator: activation: 90.38 % Charge air pressure actuator: acknowledgment: 90.38 % Ambient temperature: 17.0 °C Charge air pressure: specified value: 2689 hPa Accelerator pedal travel: 48.10 % Air mass: actual value (mg/stroke): 1093.5 mg/stroke Actual charge pressure: 2330 hPa Readiness: 0 0 0 0 X ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 4H1 927 158 CL HW: 0BK 927 156 AD Component: 0BK 30TDIRdW H16 1011 Revision: --H16--- CVN: 975A626A Coding: 000001 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMALX51011 002022 ROD: EV_TCMALX51011_002_AU64.rod VCID: 7CF79AC7F71A177397-8028 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb Part No SW: 4H0 907 379 T HW: 4H0 907 379 T Component: ESP PREMIUM H10 0665 Revision: -------- Serial number: -------------- Coding: 60E5EB8006A7D701E300 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ESPPremi 005024 ROD: EV_ESPPremi_005_AU64.rod VCID: 4385213BCA64A88B96-8016 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 EB HW: 4H0 907 064 EB Component: BCM2 2.0 H36 0521 Revision: 00002001 Coding: 05B76F4E000000000000 Shop #: WSC 02391 785 00200 VCID: 6DD1A783B4608EFB10-8038 Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C Component: J764 ELV MLB H40 0046 Serial number: 0213000400877009 1 Fault Found: 02241 - Engine Control Module; Immobilizer Data not Adapted 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 1 Fault Frequency: 39 Reset counter: 52 Mileage: 128904 km Time Indication: 0 Date: 2023.05.16 Time: 09:11:54 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels: None Part No SW: 4H0 959 760 D HW: 4H0 959 760 D Component: MEM-BFS H08 0153 Revision: AA000000 Serial number: 00000086484489 Coding: 0038320000047201000001010101112131313333283333 Shop #: WSC 02391 785 00200 VCID: 346772E797CA1F331F-8060 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb Part No SW: 4H0 820 043 N HW: 4H0 820 043 N Component: Klima 4 Zonen H20 0201 Coding: 362102B83C0000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiFront 003001 ROD: EV_AirCondiFront_002.rod VCID: 2B55699B42F440CB4E-807E 2 Faults Found: 0129 - Motor for Left Side Window Defrost Flap B10D7 22 [009] - Signal Amplitude Too High Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 16 Reset counter: 12 Mileage: 128904 km Date: 2023.05.16 Time: 08:47:51 0378 - Coolant Circulation Pump B10D0 04 [009] - Internal System Fault Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 8 Mileage: 128904 km Date: 2023.05.16 Time: 08:53:29 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb Part No SW: 4H0 907 063 AB HW: 4H0 907 063 AB Component: BCM1 2.0 H20 0242 Revision: 19020001 Serial number: 00000052629401 Coding: 0105001440349FE0C9014087A0001800009DC30A2F0802018000089461001700004000240B0000 Shop #: WSC 02391 785 00200 VCID: 68DFD6979B82ABD363-803C Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB Component: WWS641 130911 H36 0090 Serial number: 131021203832 Coding: 0045F7 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 22109416 Coding: 02004E Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B Component: E1 - LDS H07 0044 Serial number: 06 01 2014 00001353 Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C Component: EVLS-SG H08 0300 Serial number: WA107206000005727074 Coding: 020300 Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: B0C884E6000000000001 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 4H0-959-655.clb Part No SW: 4H0 959 655 H HW: 4H0 959 655 H Component: Airbag10.43 H81 0084 Revision: -------- Serial number: 003P10014JPZ Dataset Number: 4H0909602J 0013 Coding: 30333045313430303038554A305234483053 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirbaAU10BPAAU64X 001014 ROD: EV_AirbaAU10BPAAU64X_VW51.rod VCID: 3B7559DBB294D04BDE-806E Crash sensor for side airbag: driver side: Serial number: 3575HRB40672ATKA31HC Front Passenger's Side Airbag Crash Sensor: Serial number: 3585HRB40692ATKA91OS Rear Side Airbag Crash Sensor (on driver's side): Serial number: 3515JRB400450QLQFHBS Passenger side rear thorax airbag crash sensor: Serial number: 3525JRB400450QLQ713/ Crash sensor for front airbag: driver side: Serial number: 3554VRB401C50REKK0FW Crash sensor for front airbag: front passenger side: Serial number: 3564VRB401050R5M6GST No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4H0 953 568 G HW: 4H0 953 568 G Component: Lenks.Modul H04 0005 Revision: -------- Serial number: 01335NAA0004Q Coding: 000034 Shop #: WSC 02391 785 00200 VCID: 377D45EB86BCF42B3A-8062 Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A Component: E221 - MFL H08 0010 Serial number: 25 10 2013 C0368624 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1 Part No SW: 4H0 920 910 M HW: 4H0 920 910 M Component: TDieGB------- H53 0621 Revision: 36081095 Serial number: 658121213592023 Coding: 33A608001B412600010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RBD4K 004048 ROD: EV_RBD4K_AU64.rod VCID: 2E53608F71E635E369-807A Analog_clock: Subsystem 1 - Part No SW: 4H0 919 204 Q HW: 4H0 919 204 Q Component: Analoguhr D4 H05 0225 Serial number: 2131204000185 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb Part No SW: 4H0 907 468 AE HW: 4H0 907 468 AC Component: J533--Gateway H13 0050 Revision: -------- Serial number: 00000001227316 Dataset Number: 4H0909515K 0080 Coding: 80CD077D00 Shop #: WSC 02391 785 00200 GVL: FF83E858FEE3E0CF8000 ASAM Dataset: EV_GatewPkoUDS 001019 ROD: EV_GatewPkoUDS_001_AU57.rod VCID: 74E7B2E7DF4A5F33DF-8020 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F Component: J367-BDM H08 0181 Serial number: 50344G29011911505359 Voltage stabilizer: Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C Component: J532_DCDCStab H05 0006 Serial number: 13337003213021200410 No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb Part No SW: 4H0 919 158 K HW: 4H0 919 158 K Component: Klima Fond H16 0200 Coding: 2800000000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiHeck 002001 ROD: EV_AirCondiHeck_AU64.rod VCID: 387F46D783A2FB5333-806C No fault code found. ------------------------------------------------------------------------------- Address 30: Special Function II (J843) Labels: 8K0-907-440.clb Part No SW: 4H0 907 440 HW: 4H0 907 440 Component: STS H06 0030 Revision: S0H06000 Serial number: 00000000052712 Coding: 01010101000000000001000202 Shop #: WSC 02391 785 00200 VCID: 64C7C2A767AACFB34F-8030 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control (J197) Labels:. 4G0-907-553.clb Part No SW: 4G0 907 553 G HW: 4G0 907 553 F Component: LUFE-DAEMPFER H19 0783 Dataset Number: 4H0909553H 0037 Coding: 008000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirSuspe 003025 ROD: EV_AirSuspe_VW51.rod VCID: 2F6D7D8B76EC3CEB62-807A 1 Fault Found: 403200 - Function Shut-Off Active C10C8 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 48 Mileage: 128904 km Date: 2023.05.16 Time: 09:12:25 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4H0 959 760 D HW: 4H0 959 760 D Component: MEM-FS H08 0153 Revision: AA000000 Serial number: 00000086484634 Coding: 00383B0000057201000001010101112131313333203333 Shop #: WSC 02391 785 00200 VCID: 346772E797CA1F331F-8060 No fault code found. ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb Part No SW: 4H0 907 637 K HW: 4H0 907 637 F Component: SARA 6D H03 0056 Revision: -------- Serial number: EJ1BPA7701FJ99 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SARA2 005012 ROD: EV_SARA2.rod VCID: 377D45EB8EBCF42B3A-8062 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb Part No SW: 4H0 959 793 R HW: 4H0 959 793 G Component: TSG FA H06 0273 Revision: -------- Serial number: 0000086376857 Coding: 011F1E015E0162C202083006 Shop #: WSC 02391 785 00200 VCID: 489F3617FB428BD343-801C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb Part No SW: 4G0 909 144 L HW: 4G0 909 144 G Component: RCEPS H40 0010 Revision: 00001000 Serial number: 0005185981 Dataset Number: 4H0909852F 0020 Coding: 101000010001 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RCEPS 009008 ROD: EV_RCEPS_009.rod VCID: 326B74FF65DE11030D-8066 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb Part No SW: 4H0 907 064 EB HW: 4H0 907 064 EB Component: BCM2 2.0 H36 0521 Revision: 00002001 Serial number: 0323755591 Coding: 011B0E2280B93985F320C7C40A0316470000000000000000000000000000 Shop #: WSC 02391 785 00200 VCID: 6DD1A783B4608EFB10-8038 Subsystem 1 - Part No: 4H0 951 177 Component: DWA-Sensor H01 0010 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591 Component: J245 PS50.030 H08 0006 Serial number: WOO25970311 Coding: 901F00 Subsystem 4 - Part No SW: 4H0 947 135 G HW: 4H0 947 135 G Component: Dachelektroni H13 0080 Serial number: A2014000000000766217 Coding: 010000 Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A Component: V252 PS013 H06 0005 Serial number: WOO10005VW0 Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D Component: GEB.F.Heckoef H16 0811 Serial number: 93101628 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4G0 035 223 C HW: 4G0 035 223 A Component: BOSE-G3-C7 H07 0160 Revision: CJ007001 Serial number: 00000000064473 Coding: 030000 Shop #: WSC 31716 002 1048576 VCID: 1D31B7430440BE7BC0-8048 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb Part No SW: 4H0 959 792 G HW: 4H0 959 792 G Component: TSG BF H06 0273 Revision: -------- Serial number: 0000086931726 Coding: 011F1E015E0162C202083006 Shop #: WSC 02391 785 00200 VCID: 3C775AC7BF9AD773D7-8068 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 G HW: 4H0 907 801 A Component: EPB-4 H03 0014 Revision: -------- Serial number: 00000000926803 Dataset Number: 4H0909522D 0017 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_VW51.rod VCID: 2C576A8747FA47F347-8078 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb Part No SW: 4H4 907 357 B HW: 7P6 907 357 B Component: MxB-ECU 001 0049 Revision: -------- Serial number: -------------- Dataset Number: 4H0909865C 0018 Coding: 02F6022022130200 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002 ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod VCID: 31697BF360D82A1B74-8064 Left LED Headlamp Power Output Stage 1: Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB Component: LED LeiMo li. H07 7530 Coding: E00300 Right LED Headlamp Power Output Stage 1: Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB Component: LED LeiMo re. H07 7530 Coding: E00300 Power module 1 for left matrix headlamp: Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB Component: MxB LeiMo li. H03 0021 Coding: E00300 Power module 1 for right matrix headlamp: Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB Component: MxB LeiMo re. H03 0021 Coding: E00300 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb Part No SW: 4G0 035 061 N HW: 4G0 035 061 Component: Radio U DAB H60 0139 Revision: AB001007 Serial number: 109A+0E7855924 Coding: 010103010000000001 Shop #: WSC 02391 785 00200 VCID: 285F96975B026BD3A3-807C No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4H0 035 670 P HW: 4H0 035 670 P Component: H-BNT-EU H47 0798 Revision: -------- Serial number: 179A.0E7517135 Coding: 02010100000BF1EF45908B1E00000003000001000000000000 Shop #: WSC 02391 785 00200 VCID: 31697BF368D82A1B74-8064 Subsystem 1 - Part No: 8R0 060 884 BK Component: EUR 2014 1703 Subsystem 2 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G Component: DU8 D4 SV NB H48 0021 Serial number: AUZ8ZDDC90128LP Subsystem 3 - Part No SW: 4H2 919 600 H HW: 4H2 919 600 Component: E380 BDT D4 H09 0065 Serial number: 00000000143040 Subsystem 4 - Part No: 8R0 060 961 F Component: CD-Database 5571 1 Fault Found: 01524 - Antenna for Telephone 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 7 Fault Frequency: 1 Reset counter: 8 Mileage: 128904 km Time Indication: 0 Date: 2023.05.16 Time: 08:48:04 Freeze Frame: Voltage: 11.80 V ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb Part No SW: 4H0 959 795 D HW: 4H0 959 795 D Component: TSG HL H06 0273 Revision: -------- Serial number: 0000061939243 Coding: 010F1E01400062C202083006 Shop #: WSC 02391 785 00200 VCID: 3C775AC7BF9AD773D7-8068 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4H0 907 428 B HW: 7P6 907 441 D Component: TopView H05 0220 Revision: 11001001 Serial number: 82330JF0125931 Coding: 020D000001000000000102000000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_CamerSysteTopViewAUDI 007026 ROD: EV_CamerSysteTopViewAUDI_007.rod VCID: 2C576A8747FA47F347-8078 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels:* None Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC Component: HDSG-Modul H12 0046 Revision: 10012001 Serial number: 008400796 Dataset Number: 4H0909541F 0007 Coding: 021004C020 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DeckLidContrUnit 001032 ROD: EV_DeckLidContrUnit.rod VCID: 6FEDBD8BB66C7CEB22-803A No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II (J773) Labels:* None Part No SW: 4H0 907 412 HW: 4H0 907 412 Component: ALM H05 0004 Revision: -------- Serial number: 000000135495 Dataset Number: 4F0000000__ U001 Coding: 220000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_Ambie 001008 ROD: EV_Ambie.rod VCID: 63C5C1BB6AA4C88BB6-8036 1 Fault Found: 0046 - Rear Right Door Lighting Color 2 B1131 01 [009] - Electrical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 8 Mileage: 128904 km Date: 2023.05.16 Time: 08:47:55 Terminal 15 status: On Voltage terminal 30: 12.0 V Control Module temperature: 22 °C Processor load: 36.0 % Color setting Ambient: Cold white Status terminal 58s: OFF ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb Part No SW: 4H0 959 795 D HW: 4H0 959 795 D Component: TSG HR H06 0276 Revision: -------- Serial number: 0000086141064 Coding: 010F1E01400062C202083006 Shop #: WSC 02391 785 00200 VCID: 3C775AC7BF9AD773D7-8068 No fault code found. ------------------------------------------------------------------------------- Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb Part No SW: 4H2 927 731 A HW: 4H2 927 731 A Component: GSM-RL H08 0083 Revision: 0R0D5015 Serial number: SN131109 0150 ASAM Dataset: EV_GSM2x3Mono 001017 ROD: EV_GSM2x3Mono_AU64.rod VCID: 2C576A8747FA47F347-8078 No fault code found. ------------------------------------------------------------------------------- Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb Part No SW: 4H0 907 217 F HW: 4H0 907 217 A Component: DPC-SG H26 0081 Revision: -------- Serial number: 262130025421000 Dataset Number: 4H0909547F 0046 Coding: E0140000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_OnBoardCamerDPC 001007 ROD: EV_OnBoardCamerDPC.rod VCID: 2C576A8747FA47F347-8078 No fault code found. ------------------------------------------------------------------------------- Address 88: Multicont. Seat Driver (J873) Labels:* None Part No SW: 4H0 907 182 H HW: 4H0 907 182 H Component: IVB H07 0042 Serial number: 00014157217402 Dataset Number: 4H0909880D 0019 Coding: 672FF2 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_IVBDriveSideFrnt 001003 ROD: EV_IVBDriveSideFrnt.rod VCID: 2F6D7D8B76EC3CEB62-807A No fault code found. ------------------------------------------------------------------------------- Address 89: Multicont. Seat Pass. (J872) Labels:* None Part No SW: 4H0 907 182 H HW: 4H0 907 182 H Component: IVB H07 0042 Serial number: 00014157205001 Dataset Number: 4H0909881D 0019 Coding: 272FF2 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_IVBPasseSideFrnt 001003 ROD: EV_IVBDriveSideFrnt.rod VCID: 2F6D7D8B76EC3CEB62-807A No fault code found. ------------------------------------------------------------------------------- Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 945 B HW: 4H0 980 945 C Component: RGS-VL H13 0080 Dataset Number: 4H0909614C 0003 Coding: 00060000031F030000030800424CDA010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_L 002004 ROD: EV_RGS_L.rod VCID: 31697BF360D82A1B74-8064 No fault code found. ------------------------------------------------------------------------------- Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 946 B HW: 4H0 980 946 C Component: RGS-VR H13 0080 Dataset Number: 4H0909615C 0003 Coding: 00060000031F030000030800424CDA010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_R 002004 ROD: EV_RGS_R.rod VCID: 326B74FF65DE11030D-8066 No fault code found. ------------------------------------------------------------------------------- Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb Part No SW: 4H0 907 355 C HW: 4G0 907 355 B Component: SCR-Stg-G2 H09 0011 Revision: 00000000 Serial number: 132660318 Dataset Number: 4H0909571E 0015 ASAM Dataset: EV_RDCMA00100 008040 ROD: EV_RDCMA00100.rod VCID: 2C576A8747FA47F347-8078 No fault code found. End-------------------------(Elapsed Time: 07:27)--------------------------
Address 05: 02241 - The ECM needs reflashed with same or newer software. It might explain the issue you had in point 3 of your post. For other VAG cars I've read about with the same issue, there's is more severe in that the car starts and then stalls again, and continues that way.
Address 08: 0129 - Seems to be an issue that others have encountered, which is some plastic lugs (end stops) breaking off. The following thread gives further details: https://www.audiworld.com/forums/a8-...issue-3013380/ and the following video should help with removing it: https://www.youtube.com/watch?v=v_GcY17Zl-I Address 08: 0378 - Check out the following thread, which also has links to a write-up: http://forum.a8parts.co.uk/showthread.php?t=14104 Address 34: 403200 - From what I've read, it seems that this only appears if you've been into the MMI to activate the 'tyre change' option, or if the car thinks it is being jacked up. Normally the date indicates when this last happened, but all your dates are the same. Had all the error codes previously been cleared, with this scan being after that? Address 5F: 01524 - Can't find anything useful about this as most are old posts about people retrofitting BT to their vehicles. Only suggestion I have it to check the coding for Address 5F. Address 6F: 0046 - Again, can't find anything useful. Try clearing code and see if goes away. If not, try changing colour to see if that works. If not, then it might be gone completely, as the text implies (Electrical Failure).
Thanks! Actually looks straight forward enough I think I might have a bash at that, although be prepared for some blue air, as anything I touches tends to end in tears…
Ref address8 that’s good to know too, I feared the worst in terms of a pricey fix. This was my first vcds scan, however I’d had into an old school mate who has a vag Indy shop in my hometown which I happened to be visiting. He’d scanned and cleared everything on the Tuesday (16/5) then I drove home and scanned when I got home on the Wednesday (17/5). We’d had it up on the ramps to look at suspension but he couldn’t see anything other than what looked like some perishing to bushes, no excessive play etc.. we’d had in jack mode then. I’m thinking the levelling module is faulty as it will raise and drop but Ive not notice it self level on occasions when stopped on a steep junction for example. This was always noticeable in my d3. Wondered if this fault in turn could also then be aff3cting general ride if it wasn’t knowing what do do ref levelling off etc
Adding to your point about stiff suspension, do you have Towing mode enabled, as I've seen suggestions that that can attribute to the harshness? Have seen multiple references to hard suspension both on the D3 and D4, but no concrete solution to it anywhere on it's cause/resolution.
