For Sale and Wanted - Cars For the sale of whole cars, Audi or not, working or not. No cross links to other peoples cars please - Use Spotted online instead |
Morning all
I think I've come to the end of the road with my S8. It's been about 7 years and I've loved her to bits but I can't really afford to keep her on the road any longer and I'm hoping someone else can. 2002 in Aqua Pearl (rare metallic blue/purple) Black leather with dark wood inlay Factory bootlid spoiler 136k miles Part service history (last service was Feb last year) MOT until end Feb Good bits: Original Milltek backbox - these are super rare now Recent custom build stainless steel exhaust with 200 cell sports cats from from down pipe to back box 20" OEM wheels recently refurbished in storm grey, with painted black calipers and S8 decals on them. Looks fantastic. Original Sat Nav in place Black leather has held up well - really lovely feel. Back seats have hardly been sat in New window motor installed on driver's side F125 switch done 5 years ago (but may need replacing again - couple of fault codes earlier this year make me think its a possible weak spot still) Bad bits Front bumper needs a respray as laquer is peeling Cam belt service due but car has done less than 2000 miles since the last one Coolant level warning light keeps coming on - coolant levels are fine and she runs at a rock solid 90 degrees all day everyday. Its a wiring issue to the instrument binnacle which needs an auto electrician to sort. Headlight level sensor needs replacement It drives phenomenally well - pulls brilliantly and runs like a dream mechanically. The new exhaust makes it sound unreal and releases as much power as is available from 4.2 40v. But I can't afford to spend the money on the bad bits above - so its time to move her on. Will be heading on to Pistonheads next week for £4k but for a genuine forum member it's available for £3.5k. Hope someone can enjoy her as much as I have. Sad times....
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust. |
Are the rubber floor mats genuine audi ones? they are ultra rare.
Yes they are. I had no idea! The driver's side one has a hole in it.
Just to add that I thought I recognised this car when it arrived on my driveway yesterday and I was told it's previous owner was Professor Peach on here. He hasn't posted in at least 5 years though.
If Richard is happy I can post the codes from the VCDS scans (second one after a cleardown and run around the block).
No problem with that Andrew.
So the final scan (clean sections omitted) was:
Thursday,05,October,2023,11:54:15:38881 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 23.3.1.0 (x64) Data version: 20230421 DS346.2 www.Ross-Tech.com Scan: 01 02 03 08 15 17 35 37 45 55 56 76 VIN: WAUZZZ4D63N001043 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 4D0 907 389 E Component: ABS/ESP allrad D57 Coding: 08397 Shop #: WSC 02313 VCID: 316F2301FBBEBB1B74-5178 1 Fault Found: 01119 - Gear Recognition Signal 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels:. 8D0-862-257.clb Part No: 8L0 862 257 P Component: CV-Pump, Alarm, RC D17 Coding: 16235 Shop #: WSC 02314 VCID: 428D7CCD4E1830839D-4F02 1 Fault Found: 01134 - Alarm Horn (H12) 49-00 - No Communications ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00001 Shop #: WSC 00000 VCID: 0401BAD5148CFEB3EF-4B4A 1 Fault Found: 00776 - Level Control System Sensor; Left Front (G78) 28-10 - Short to Plus - Intermittent End-------------------------(Elapsed Time: 02:14)-------------------------- And the first scan had the following additional errors: ------------------------------------------------------------------------------- Address 01: Engine Labels: 4D0-907-560-AVP.lbl Part No: 4D0 907 559 AA Component: 4.2L V8/5V G 0002 Coding: 10753 Shop #: WSC 02629 VCID: 6DD7FF7127061FFB10-5178 WAUZZZ4D63N001043 AUZ7Z0A2019960 6 Faults Found: 16804 - Catalyst System; Bank 1 P0420 - 35-00 - Efficiency Below Threshold 18010 - Power Supply Terminal 30 P1602 - 35-10 - Voltage too Low - Intermittent 16814 - Catalyst System; Bank 2 P0430 - 35-00 - Efficiency Below Threshold 17819 - Secondary Air Injection System; Bank 2 P1411 - 35-10 - Insufficient Flow - Intermittent 17831 - Secondary Air Injection System; Bank 1 P1423 - 35-10 - Insufficient Flow - Intermittent 17521 - Oxygen (Lambda) Sensor; B1 S1 P1113 - 35-10 - Internal Resistance too High - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01L-927-156.lbl Part No: 4D0 927 156 EC Component: AG5 01L 4.2l5V RdW 1010 Coding: 00111 Shop #: WSC 02314 VCID: 6ED5F87D2A00E4E329-5178 3 Faults Found: 17090 - Transmission Range Sensor (F125) P0706 - 35-10 - Implausible Signal - Intermittent 17147 - Shift Solenoid 3 (N90) P0763 - 35-10 - Circuit Failure - Intermittent 17142 - Shift Solenoid 2 (N89) P0758 - 35-10 - Circuit Failure - Intermittent ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 4D0 907 389 E Component: ABS/ESP allrad D57 Coding: 08397 Shop #: WSC 02313 VCID: 316F2301FBBEBB1B74-5178 2 Faults Found: 01203 - Electrical Connection between ABS and Instrument Cluster 31-10 - Open or Short to Ground - Intermittent 01119 - Gear Recognition Signal 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl Part No: 4D0 820 043 Q Component: A8-Klimavollautomat D13 Coding: 00081 Shop #: WSC 02314 VCID: 2A5D346DD668C8C3B5-2592 1 Fault Found: 00734 - Potentiometer in Central Vent (G142) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels:. 8D0-862-257.clb Part No: 8L0 862 257 P Component: CV-Pump, Alarm, RC D17 Coding: 16235 Shop #: WSC 02314 VCID: 428D7CCD4E1830839D-4F02 9 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00955 - Key 1 09-00 - Adaptation Limit Surpassed 00956 - Key 2 09-00 - Adaptation Limit Surpassed 01134 - Alarm Horn (H12) 76-00 - Terminal 30 missing 01134 - Alarm Horn (H12) 77-00 - Internal Supply Voltage 01134 - Alarm Horn (H12) 49-00 - No Communications ------------------------------------------------------------------------------ Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl Part No: 4D0 035 192 M Component: RNS 4.2 H06 BNO 0102 VCID: 295FCB61D36EC3DBBC-4B18 1 Fault Found: 00862 - Antenna for GPS Navigation (R50/R52) 44-00 - Short Circuit ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-178.lbl Part No: 4D0 951 177 B Component: Innenraumueberw. D06 Coding: 00001 Shop #: WSC 00000 VCID: 2859CE65C864FAD3A3-5178 1 Fault Found: 01462 - Anti-theft alarm ultra sonic Sensor (G209) 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00001 Shop #: WSC 00000 VCID: 0401BAD5148CFEB3EF-4B4A 2 Faults Found: 00774 - Level Control System Sensor; Rear Left (G76) 28-00 - Short to Plus 00776 - Level Control System Sensor; Left Front (G78) 28-10 - Short to Plus - Intermittent ------------------------------------------------------------------------------- The central vent potentiometer issue I've had myself and fixed by moving the dial back and forth a few times. I did that to this one too. ![]()
For £3.5k I'd buy it, as it's a S8 and in better condition than mine, bodywork wise. Have done the cam belts and F125 switch on mine, so that's a doddle. Now if I only had £3.5k. Shame you have to part with it. GLWS.
