Old 20th November 2023, 03:50 PM
Default Rustproofing with Lanoguard
Well, at my last MOT, the mechanic said that the S8 was "looking a bit 'crusty' underneath, and I knew that the subframes were in need of some TLC. So, after a bit of research, I found a Lanoguard franchise not far from me (close to Oakham) and took the S8 alomg.
The guy (Greg at 4Play Jeep) was brilliant and talked me through the process (which took close to a week including the time for the stuff to 'cure') and took photos every step of the way. I was so impressed that I went to pick the S8 up today and left the TTS to be done as well.
Phots below show 'before' (5862 and 5883), after steam cleaning and wire-brushing (5884 and 5861), after application of sticky stuff with a brush and almost 5L of Lanoguard with a spray, whilst it's still wet and uncured (5913 and 5910), and the completed job beginning to cure.
Hopefully, the imminent MOT will not elicit the 'crusty' comment again.
Ah, having trouble uploading photos. I'll try the first 4 here and then the second 5 in a subsequent post. No luck - I get this message "The resource you are looking for has been removed, had its name changed, or is temporarily unavailable". I'll try again later. It worked when I uploaded one photo at a time.
ID:	30023   Click image for larger version
ID:	30024   Click image for larger version
ID:	30025   Click image for larger version
ID:	30026   Click image for larger version
ID:	30027   Click image for larger version
ID:	30028   Click image for larger version
ID:	30029   Click image for larger version
ID:	30030   Click image for larger version
Old 20th November 2023, 04:40 PM
I think Lanoguard is what my 100HP specialist in Leicester will be using on mine when it's in next week to be fettled - as it spent the first decade of it's life in Aberdeen, I think it'll need it!
Old 22nd November 2023, 05:29 PM
donp38 donp38 is offline
Any update on the Fiat?
I did mine earlier this year with this stuff.
Looks good....but maybe an annual application?
Old 23rd November 2023, 06:24 AM
I was told that an annual inspection and ‘patch up’ might be required, not an annual application.
Old 23rd November 2023, 11:17 AM
Ronin Ronin is offline
This looks like covering rusty metal with oil to slow down the rust by cutting off oxygen, a lot of 2.8s came with this option from the factory 😁
Old 24th November 2023, 03:48 PM
Date's gone back to 4/12, and probably won't get it back till ~ 16th, but will update you when I do....
Old 27th November 2023, 08:50 PM
In my younger days they sprayed old oil under cars as a matter of course in Germany but stopped when they started using underseal on new cars.
Old 28th November 2023, 10:11 AM
See Ronin's comment above.
Old 20th February 2024, 09:38 PM
Very belated update - this is the stuff being applied to my Fiat (Panda...):https://www.cleanyourcar.co.uk/bilt-...rust-converter
