Old 8th December 2023, 06:07 PM
Default Brake bleeding problems
I’ve had all my calipers refurbished at BCS, having had them removed and refitted by a local garage. But the garage is having trouble bleeding the brakes. Apparently, there is brake fluid at the calipers, but no pressure.
My usual garage (who didn’t want my car on a lift for days whilst the calipers were refurbished) have bled the brakes before with excellent results (my brakes had never been better). The garage that has the car just now is making noises about dirty brake fluid, ancient master cylinder and very high mileage, but I have no idea if any of this is valid.
Are there any key tips that might help get this sorted? All thoughts welcome as the car is due for a service and MOT on Monday.
Thanks, Jim
Old 8th December 2023, 06:18 PM
I wonder if when all the calipers were off, the brake fluid leaked out enough and there's now air in the ABS unit. Hopefully MJ will spot this and give you the definitive answer, as opposed to some thoughts.
Hope you get it sorted by MOT time Monday.
Old 8th December 2023, 07:11 PM
I presume they're following the correct procedure to bleed the ABS pump using VCDS.......
Old 8th December 2023, 07:21 PM
Is there a link to the correct procedure somewhere?
Old 8th December 2023, 07:27 PM
They are probably either trying to vacuum bleed it which simply won't work, or bleeding it with the pedal which is very high risk on a 20 year old car as any moisture or corrosion in the far travel of the master cylinder (inevitable in D2s which seem to mostly have brake fluid like seawater) will trash the seals when you press the pedal to the floor.
The solution is to pressure bleed it with 2 bar of pressure required to get through the ABS unit. You have to have a proper tool for this. Good luck to anyone trying to pull 2 bar of vacuum
Just changing the calipers doesn't need the ESP pump bleeding, but if they have let it run dry it'll need basic settings running on the pump to cycle the fluid through.
Old 8th December 2023, 08:07 PM
Ronin Ronin is offline
There is a pdf with instructions here:
https://****************/viewtopic.php?t=17
MJ is right, doing it with a proper tool makes all the difference, the last time I had it done 2l of brake fluid was enough to flush through and bleed everything.
The tool looks like this:
https://www.ebay.co.uk/itm/223639876...Bk9SR4LxirSJYw
