Here we will post links to Engine related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
To Start the Ball Rolling here are some classic links from Paul W's Audipages. This site can't be recommended enough as a gold mine of information about your 8. Breather Hose replacement - Audipages CAMBELT CHANGE ABZ 4.2 V8 4.2 ABZ Engine Cambelt Change Procedure- Audipages Part Numbers for above Cambelt Change - Audipages The Tools You'll need - Audipages OTHER TASKS Cooler expansion Tank Replacement- Audipages Cooler Expansion Tank Replacement - Entwisi Engine Fan (Electric) Removal and Replacement- Audipages Engine Removal and Re-installation - Conan the Librarian ---------The Story Behind the Engine Change - Conan the Librarian Fuel Line Leak (High Pressure) Repair Procedure- Audipages Fuel Tank Sending Unit Seal Replacement- Audipages VW Audi Oil Spec Information - DavidS8 Oil and Filter Change (32 & 40 V)- Audipages Oil Cooler Removal and Re-install- Audipages Spark Plug replacement- Audipages Valve Cover Gasket Replacement- Audipages Compression test results ABZ - ainarssems 40V Intake manifold fix for stuck or sluggish flap pivots (no broken parts) - SilverD2 from Audiworld Symptoms and their Explanations Noisy Tappets - Architex_mA8tey et al The ultimate guide to the V8 and other resources - R8dream Manifold flaps repair document pdf - Download this document which will both explain it all and show a way to possibly fix stuck flaps http://forum.a8parts.co.uk/attachmen...9&d=1578778374 Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. ![]() Last edited by Architex_mA8tey; 8th February 2022 at 09:07 AM. Reason: Updated |
