Old 23rd July 2012, 05:58 PM
Karstad Karstad is offline
Default Foglight error
On my audi A8 d2 3.3 TDI the fog lights just stopped working one day. The fuse on the passenger side is ok, aswell as the bulbs. What is the problem?
When i push the foglight switch nothing happens, its dead. not even a light comes on inside dashboard.
Any ideas?
Old 23rd July 2012, 06:05 PM
relay or wiring broken?
Old 23rd July 2012, 06:10 PM
don't think its the wiring because it happened so fast. i started the engine, switched one the lights and hit the foglight switch. The green light came on for less then a second and haven't worked since.
Where can i find the relay?
Old 23rd July 2012, 10:18 PM
Its on the relay board (item 2 on the pic shown) which is under a wooden cover plate in the passenger footwell
Relay is part No 8D0907701A
control unit for fog lights and rear fog light / relay location/code no.:
3+8/397 /
Name:	Relay board.png
Old 24th July 2012, 06:30 AM
found it, thanks
how do i check if its broken?
Old 24th July 2012, 07:48 AM
Does anyone know how to get the foglight switch out?
think the switch is broken since the rear foglight switch works.
Old 26th July 2012, 07:21 AM
As noted above these symptoms point with very high certainty (if it's ALL fog lights) to a control unit/relay or fuse.
Fuses usually blow for a reason though......
Sometimes relays are standard units and there can be several identical ones in a car, facilitating "testing by swapping"; in this case though it's less likely due to the interlinked way foglights work with multiple inputs and multiple outputs.
Personally I would identify it and see if A8 parts have one available. Probably the cheapest method of initial diagnosis and quite likely a fix too.
Old 26th July 2012, 10:41 AM
i used a multimeter to check bulbs and fuse.
yesterday i did get the foglight on by accident. the multimeter pin connected to circuits when i was trying to measure the switch. So i don't really know what the problem is since both the switches works fine one rear foglight.
Old 26th July 2012, 04:54 PM
sloss's Avatar
sloss sloss is offline
Like I said...
If you know nothing about electrics then I suggest you get someone who does as you could cause a lot of damage......
You were lucky that whatever you shorted caused the lights to come on, if you'd put the volts directly to earth it could have been serious
Best to get help
