Hi all
Am I imagining that there was a thread on here regarding a fix on the wiring of the headlight, that solved faults in the 'see around corners' function? I have had this fault for about a year now and have mustered the courage to have a go at resolving. So I started with the suspension height level sensors, giving the connections a clean etc but that doesn't appear to be the root cause. I am sure there was a discussion about a section of the headlight wiring splits/separates but a forum search returns nothing. Does anyone else recall the thread?
'09 D3 S8 - Most of the bells and whistles (B&O, Audi Exclusive brown interior and exterior paint, soft close, ACC etc) de-flapped manifold! |
New to the D3 scene but have always read the posts anyway. Mine has the same fault, but has only happened three times since I got it at the start of February. I'm sure I've read somewhere that the reason for the fault occurring was due to the wiring being too short to the light and that the movement caused the wires to fracture.
I'd be interested to hear of anyone has ever changed that particular bulb as the yellowish colour looks cheap compared to the whiter headlights. Too cold, no garage and no patience at the moment to even look at it.
I managed to do a couple of adaptation scans for another member, but I had the engine running to keep me warm. the main job I need to do is driver.s door mirror heating. Need it during cold weather but it is too cold to bother. Catch 22 ![]()
Do you have the adaptive headlight warning error light on the display?
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment ![]() 2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot 2022 Mercedes EQC 400 Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS 2008 A8 3.0 Tdi sport, B&O |
And yes Kele, I have the yellow headlight with an arrow DIS warning. It used to annoy me each time I started the car but now I hardly notice, that is until the wife reminds me “what’s that flashing light?” Oddly enough her A6 C6 Avant has the same fault!
https://www.youtube.com/watch?v=gKngB6OcPvA Unfortunately, the wiring in question is inside the headlight unit, and that means bumper off to remove the unit, and then fix. Given what he says in the video, I suppose you could preempt the problem by replacing the cable tie and allowing for a bit more movement.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! ![]() My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 20th March 2018 at 11:34 AM. Reason: Cable tie line |
I have read about it on A6 sections of other forums, not on here.
I wondered at the time if it affected our A8s as they are very similar lights (very bad quality for such an expensive car) |
OK. On mine I had the same symptoms. It turned out to be the headlight control module....
Just a case of 'German efficiency' being just a tad too efficient with the cable tie.
