Old 18th April 2018, 09:01 PM
Hope your is a similar easy fix.
Not so much
Only two pictures tonight.
This one
and this one (this is a spare harness btw!)
Don't have nightmares!
ID:	18499   Click image for larger version
Old 18th April 2018, 09:42 PM
27litres's Avatar
27litres 27litres is offline
All depends if the problem was already there, or has just appeared!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 18th April 2018, 09:50 PM
Zip's Avatar
Zip Zip is offline
Question
Fixed a broken headlight tab
Hi Mikki....can you buy those tabs separately, and if so how have you fastened it on?
Thanks,
Zip
Old 18th April 2018, 10:22 PM
Thanks,
Zip
You can buy kits from eBay, around the £45 mark.
Old 18th April 2018, 10:23 PM
Not so much
This one
Looks like the cats have been playing with them.
Old 19th April 2018, 06:36 AM
This came from TPS. I'll check the price later.
Old 19th April 2018, 07:22 AM
Djinny's Avatar
Djinny Djinny is offline
Not so much
It all started with the interior lights blinking on / off while driving.
Then the car started to believe the the back door on the passenger side was open. The error memory said: it's the back door's lock.
So changed the back door's lock for a brandnew one.
The error memory kept on saying: back door's lock.
Changed the control unit. That did not solve the problem either.
So pulled the fuse for the interior lights and hoped for better times.
The S8 slept for 5 months during winter, afterwards it now believes it is both back doors, not just one, and sometimes all of those doors.
No obviously broken wires in the doors.
So as it turns out, it is pretty unsolveable. If anyone can find it, it is MikkiJayne.
S8 FL manual drive, 11/1999, pelican blue, customized by the Quattro GmbH, KAW 60/40, Supersport silencer, 19" from the S8 D3.
LPG & 385mm front brakes (D3).
Old 19th April 2018, 07:47 AM
pete-p's Avatar
pete-p pete-p is offline
Not so much
I'm glad I didn't see this until the morning!
Cars...
Old 19th April 2018, 07:54 AM
Well, on the plus side, at least she's working on a LHD car, which means for once, the elsawin wiring diagrams will make sense without the usual guestimation to allow for conversion to RHD
Old 20th April 2018, 08:41 PM
The electronics are still kicking my arse so had a break and did some other things. I've been a bit lax on the photos so we're missing a few 'finished' shots, but I'll catch up on those later.
The stupid plastic rivets in the two strut top covers really annoy me since you either destroy them getting them apart, or lose the pin of the rivet. So instead, a little upgrade to improve ease of use:
Open out the hole to 7mm
Insert an M5 rivnut
Affix in place with an M5 bolt. Much better I did the same on the other side with the cover behind the header tank
Next, repair the driver's side lower dash. Its quite common for the pocket to have broken off the main panel since its only plastic welded in a couple of places.
After a wipe with acetone, heat up the plastic with the hot air gun. This helps the glue bond
Stick it back together with hot-melt glue
Same problem with the steering column surround - I think someone had forcibly removed this to fit some aftermarket electronics.
Good one on the left. Unfortunately left and right hand drive are different so I can't just swap them so hot-glued the original back together then improved the fitment of the mic for the phone handsfree kit.
The wire was previously wedged in the broken trim. Peel back the felt and cut a slot for the wire
Feed in the wire and stick the bracket down then put the felt back and its much neater.
There needs to be a special place in hell for the bloke who invented scotchlock connectors The only fix for this is to cut it and crimp it back together. Its too thick to solder properly. There were half a dozen in this state.
Tidied up the wiring in the dash
A nice thing about single-DIN cars is there is space for modules under the climate control. TPMS on the left, noise filter for the radio on the right.
Surplus wiring removed plus a pile of nasty scotchlocks.
ID:	18511   Click image for larger version
ID:	18512   Click image for larger version
ID:	18513   Click image for larger version
ID:	18514   Click image for larger version
ID:	18515   Click image for larger version
ID:	18516   Click image for larger version
ID:	18517   Click image for larger version
ID:	18518   Click image for larger version
ID:	18519   Click image for larger version
ID:	18521   Click image for larger version
ID:	18522   Click image for larger version
ID:	18523   Click image for larger version
ID:	18524   Click image for larger version
ID:	18525   Click image for larger version
