Sorry, it must be your previous convictions for fixing things that arose my suspicions
Guilty as charged
How could the replacement have been faulty? It was working perfectly fine after it was installed. The only thing I can say about it is that it wasn't a new part and failed within around 500 miles of fitting. What's the vulnerability in them - is it the fairly extreme-angled routing of the cables? The other thing is that shouldn't the car unlock without me ever having to touch it, shouldn't it unlock with me just approaching the car?
Phantom Black 2008 A8 3.0 TDI SE ASB |
No, it should only unlock when you touch the handle
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
No, before my driver door handle had it's latest issue, it would unlock as I approached the car. This then reduced to unlocking only when pulling the handle once, and then reduced further its current state of not working at all.
I checked the owner's manual since - ![]()
Interesting. So prior to the fault, if you walked towards the vehicle (and was close by), did the car unlock and indicators flash without you having to touch the handle?
If this is the case, I wonder if there is a setting in the MMI for this. Even though I have keyless entry/start on the S8, I rarely used it, and never gave the car a chance to use it if available, as I would use the remote to unlock the car as I approached it. I think I only ever used the Start button 2 or 3 times to see it in operation, as it doesn't lock the steering column when you press Stop (you have to press and hold it for a few seconds).
In my experience with fully working door handles the car doesn't unlock when you walk by, it only unlocks when I put my fingers under the door handle.
This is not pulling the handle, it sense proximity. If you need to pull the handle its not working as intended and if it unlocks as you approach the car i'd say that it thinks your fingers are below the handle, also not good.
Del ![]() |
I would agree that the sensor thinks something (the OP) are touching the handle and so unlocks when near by
