Old 27th September 2022, 08:25 AM
coronaman coronaman is offline
Default Replacement suspension level sensor linkage
Morning All,
A few days ago I got the yellow suspension warning light while driving, and upon inspection the front suspension on my A8 D3 is permanently set to it's highest level, looking quite odd!
I had a look underneath and it seems as though this has been caused by the ball joint failing in the level sensor linkage on the front near side, so the sensor (which was left in it's highest position - i.e. lowest car ride height) was no longer connected to the lower wishbone.
Pleased that the issue seemed to be a simple mechanical fix, I've attempted to find a replacement part but a new linkage is only available with a new sensor at an Audi price of ~£200 which, frankly, I don't want to pay for a tiny linkage! Although a replacement used part is cheaper, I'm concerned that it will be similarly worn to the one that's just gone on mine and not last much longer.
Does anyone have any ideas about the best way to get hold of a suitable replacement linkage for a reasonable cost? I'm calling around breakers yards to see if anyone's got a broken sensor and attached linkage I can have but am not getting anywhere. It seems a little odd that a ball joint, particularly one in the high wear position this one is, cannot be replaced by itself!
Kind regards,
Simon
Old 27th September 2022, 10:37 AM
Several options available. Part number is 4E0941285G for reference.
1. Chinese made on eBay around £50 e.g. https://www.ebay.co.uk/itm/165136880601
2. Non OEM on Autodoc from around £63
3. OEM on eBay (Lithuania) from around £135 e.g. https://www.ebay.co.uk/itm/382747490401
4. OEM for £200 - https://www.scuderiacarparts.com/par...0210.html#spec
BTW Welcome to the forum. For future reference, it would be helpful if you update your signature line with details of the car e.g. year, engine, etc. so that anyone willing to help knows exactly what the specs are, as part numbers vary. Also, pop along to the Introductions section and introduce yourself... we also like photos
Tags
level, linkage, sensor, suspension
