On the way to work this morning, the ABS lights came on and then I noticed that the car had no 'oomph'. The revs seemed to climb, the engine didn't respond to the throttle.
It felt a bit like it was in limp mode, but the gear lights weren't on and it was apparently changing gear OK. Any ideas?
no idea but first thing would be to plug the car into VCDS and do a full scan.
2001 S8 D2 ![]() |
Mine always clears with a throttle "blip" (off/on), how did yours?
Had it replaced at Audi in the end. Z
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
Expensive?
I had a similar problem a while ago too, but in my case it was the ABS pump.
As I understand it, you'll get the loss of power symptom with most ABS faults, since the traction control makes the assumption that a wheel may be slipping and therefore limits the power. In my case, the fault was very intermittent at first, but (from memory) it would usually put the ABS light on, which remained on until cleared, by turning the ignition off and on. Sometimes it wouldn't happen for days or weeks; other times it would happen several times in one day. Eventually the fault became permanent. When the pump was diagnosed, I assumed they meant the pump built into the ABS controller unit under the bonnet, but it turns out there's a separate pump on vehicles with ESP, hidden away behind the n/s front wheel arch (I think). Not sure exactly how much the new pump cost in the end, but it wasn't cheap; 2 or 3 hundred quid at least I think.
A8parts have a throttle position sensor at £25.99 and ABS pumps starting from £110, although as HP says, it's sounds very similar to the fault he's had for ages, which I've also experienced a few times as well, but no ABS light.
Can't remember....it wasn't peanuts at Audi main dealer though...
I'll check when I'm back home later in the week. Z
Jim, is ABS light still on?
What VCDS is saying?
I'd rather drive on left |
Any idea where that actually fits and how easy it is to swap?
