If you can, yes. Never seen that before with a wrong graphic in the instrument cluster.
![]() Forgot that door and seats both had ECUs. ![]() BTW; my car has 4E2 959 802B [Driver 42] and 4E2 959 801B [Passenger 52] and both have the same coding; as you'd expect. Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
There isn't a specific setting for MPG; I presume this is set from the units in the Car menu. Julian
In the instrument cluster the fuel consumption is displaying as xx l/km (l/100km) which I can`t seem to change. In the hidden menu I get this under the MMI settings (see attached pic)
Current: MY57 Audi A8 3.0 TDI Quattro SE, Silver, Black Comfort Heated Leather, MMI High 2G, Bluetooth, Nav, Voice Control, AMI, Rear Camera, 6CD, 20 inch 9-spoke alloys [in Black], Folding Mirrors, 3-spoke S Line steering wheel + mods to come ![]() |
I think you're going to need a VCDS scan anyway, as to really try and check these two issues out, members of this forum will want to see part numbers, HW/SW versions and coding settings of the Instrument panel and door ECUs to make progress ... Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! Last edited by JulianHicks; 14th February 2017 at 05:54 PM. Reason: Changed text |
I'm getting more and more confused with your issues if I'm honest.
See attached photo for changing the units Press Car > Setup > Setting in top right corner and then go to Meassuring Units If that won't solve the problem there could be incorrect coding in your cluster or other units. About the doors. I wonder if you have a passenger unit fitted on driver's door or this unit coded as passenger. A full VCDS scan would be best place to start mate. What version of MMI have you got by the way ??
This is the version info from my car: SW: D3-HU 55.7.0 0835 HW: D3-HU 6300D2.0 FC SW: 06231AFC6AB320050 FC PS: 0050 FC HW: H01
So, you have the latest MMI version which is good, at least we know its not the MMI software glitch.
Now, if you can access green menu, go to DIAG SETTINGS and untick linkslenker which LHD, if its not in in DIAG then check all the other menus and submenus please.
Messed up wiring on the main plug??
Possibly has been messed around and pins are other way round on the pain connector. Unlikely, but without good history of the car and no VCDS to identify if left door is wired as left door and vs I hope its just something along the lines of coding or adaptation channels. Let us know, if still no luck I will jump on mine and see if I can ''create'' your issue on my car coz then I will know where you need to go and what value you must put to get it finally fixed.
