Old 6th March 2018, 09:44 PM
RS6's Avatar
RS6 RS6 is offline
Default Trouble with cigarette lighter front socket tray help!
Last night i had my TomTom attached in the car as usual got to my destination no problems, and then on my return leg it lost power being the battery is no good on the tomtom it needs power, for some reason the cigarette lighter socket refused to work i tried and tried rotating the power socket everything pulling it in and out reseating it nothing... i managed to make it home using the cars built in sat nav luckly the area was mapped this time but i was not best pleased tbh! plus it was pouring with rain!
Made it home ok put the car on the driveway, before i switched off the engine i closed the cover again and tried it one last time, now its working fine for the tomtom, i then plugged in a snooper device with a power cable and it worked again! thought maybe a fuse had blown but no
Does closing the cover reset the power to the socket on and off?, peering into the socket it looks rusty, how can i clean it up, disconnect the battery? or can i remove the whole tray out, my last attempt it started sparking when i tried to clean up the connections and i was doing it very gingerly meh!
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 6th March 2018, 09:50 PM
They are a funny size, definitely non-standard, I've had problems with all sort of accessories.
Old 6th March 2018, 09:56 PM
There's no electronics or switching in there. Its just straight 12V power. The ashtray only comes out with the entire centre console out unfortunately - not a small job!
Can the cable reach the rear cig lighter at the back of the centre console? I find that one is much more reliable for charger connections, and the wires tuck down beside the seats so don't get in the way. Plus its rarely used for lighting cigarettes so its not usually as crusty as the front one.
Old 6th March 2018, 10:08 PM
You're right on reliability MJ, I always use that one to plug in my tyre pump.
Old 7th March 2018, 09:06 AM
I tend to use the rear one too. If I recall correctly, the rear one is switched on/off by the red button in the driver's door (the one that also enables/disables the rear window buttons).
If the TomTom power cable won't reach, you could probably buy a longer one or a simple extension like this:
https://www.ebay.co.uk/itm/12V-Car-C...w/162020896749
Old 7th March 2018, 09:23 AM
I didn't know that about the window switch! Very handy
Old 7th March 2018, 09:52 AM
Wow, I knew something about 8s that you didn't know! That's gotta be a first (and probably last)
Actually, the button is black (I was thinking of the memory seat on/off button) but it definitely turns the socket on/off. I know this because I have my Steelmate TPMS Bluetooth receiver plugged into the rear socket most of the time, which illuminates when it gets power. Interestingly, that socket also powers up when you unlock the doors, presumably linked to the interior lighting.
Old 7th March 2018, 10:10 AM
Well I never, just tested it. Never have kids in the back so don't use the window inhibit button, but see the logic on safety.
Old 7th March 2018, 01:58 PM
.. and you dont want them lighting up in the back wihen your back's turned.
PS. Mark , you must win a prize for knowing something MJ didnt.
Old 7th March 2018, 02:18 PM
So less than one hour for one of us to confirm what Mark had said
Well done to Mark for knowing something MJ didn't (a rare event), and Andrew for being the first to confirm it.
So, how long after the annual meet will someone post about their rear cigarette lighter not working anymore? Know anyone you want to annoy while they're not looking.
