Old 19th March 2018, 10:13 AM
Default Headlight fault
Hi all
Am I imagining that there was a thread on here regarding a fix on the wiring of the headlight, that solved faults in the 'see around corners' function?
I have had this fault for about a year now and have mustered the courage to have a go at resolving.
So I started with the suspension height level sensors, giving the connections a clean etc but that doesn't appear to be the root cause.
I am sure there was a discussion about a section of the headlight wiring splits/separates but a forum search returns nothing. Does anyone else recall the thread?
Old 19th March 2018, 05:47 PM
New to the D3 scene but have always read the posts anyway. Mine has the same fault, but has only happened three times since I got it at the start of February. I'm sure I've read somewhere that the reason for the fault occurring was due to the wiring being too short to the light and that the movement caused the wires to fracture.
I'd be interested to hear of anyone has ever changed that particular bulb as the yellowish colour looks cheap compared to the whiter headlights. Too cold, no garage and no patience at the moment to even look at it.
Old 19th March 2018, 06:06 PM
+1 Sean.
I managed to do a couple of adaptation scans for another member, but I had the engine running to keep me warm.
the main job I need to do is driver.s door mirror heating. Need it during cold weather but it is too cold to bother.
Catch 22
Old 19th March 2018, 07:13 PM
kele kele is offline
Do you have the adaptive headlight warning error light on the display?
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 19th March 2018, 11:33 PM
.... I'm sure I've read somewhere that the reason for the fault occurring was due to the wiring being too short to the light and that the movement caused the wires to fracture.
Yes, this! I’m positive that is what I read, now where is it.......
And yes Kele, I have the yellow headlight with an arrow DIS warning. It used to annoy me each time I started the car but now I hardly notice, that is until the wife reminds me “what’s that flashing light?”
Oddly enough her A6 C6 Avant has the same fault!
Old 20th March 2018, 11:29 AM
I'm positive I've read it here as well but haven't found anything using the Search tool. However, I did find the following video on YouTube:
https://www.youtube.com/watch?v=gKngB6OcPvA
Unfortunately, the wiring in question is inside the headlight unit, and that means bumper off to remove the unit, and then fix.
Given what he says in the video, I suppose you could preempt the problem by replacing the cable tie and allowing for a bit more movement.
Old 20th March 2018, 11:32 AM
And bumper off means both wheel liners out...
Matt
Old 20th March 2018, 11:39 AM
I have read about it on A6 sections of other forums, not on here.
I wondered at the time if it affected our A8s as they are very similar lights (very bad quality for such an expensive car)
Old 20th March 2018, 07:56 PM
OK. On mine I had the same symptoms. It turned out to be the headlight control module....
Old 20th March 2018, 09:26 PM
That might be the case for me as well, but not saying which one (if I could remember). No free advertising 'other' forums.
From the video I linked to, it seems to have affected quite a lot of the Audi range.
Just a case of 'German efficiency' being just a tad too efficient with the cable tie.
