Old 8th May 2019, 03:40 PM
nath nath is offline
Default Etka parts numbers
guys does anyone have the etka part numbers available
For the rear suspension parts
In particular the rear track or tie rods
Just been quoted 500 per side and cant even find a picture online of what it looks like
Thanks
Guys
Old 8th May 2019, 05:25 PM
homer simpson's Avatar
Thanks
Guys
Bit more info of the car needed. Model and year minimum, VIN would be even better
Old 8th May 2019, 05:26 PM
Here is a diagram of the rear axle, with the 'track rod' number highlighted (10).
The part number is 8K0501529L and both left and right are the same. The price in ETKA (mine anyway) shows a price of £53.40. With that in mind, and the price you've been quoted, I'm wondering if your description and the ETKA description are misleading somehow.
I've also attached a couple of screenshots showing the part numbers for everything else on the rear axle.
Another resource that you might want to investigate is the following site:
https://audi.7zap.com/en/rdw/
It is essentially an online version of ETKA, and you can see the same sort of exploded diagrams that ETKA uses.
Finally, I'd suggest that you add a signature line to your account with your car details in it, so that anyone wishing to help can see immediately what sort of car you have (e.g. year, engine size, fuel), as parts can be different depending on certain aspects.
ID:	21575   Click image for larger version
ID:	21576   Click image for larger version
