Hello!
Following the destruction of my D2 S8 gearbox about 4 months into ownership (boo hoo, it will live again!) I am looking for a cheap way back into shorter-term D2 ownership. So question. How long should this job take to be done properly? I haven't priced the parts up yet, I'm just looking for an idea so I do not get ripped off. I know this is a four-figure job btw.
2002 D2 S8 - Avus Silver, Valcona red leather, Dark Myrtle wood inserts, Heated rear seats, Heated windscreen, Auto dim rear view mirror, Bose, Xenon Plus, Servotronic, Extended leather, Heat & UV Reflective glass & Ski hatch. Gearbox went bang but she's sleeping safely away. |
However, this does NOT include replacing anything else like tensioners or pulleys. If there is anyone on here who could give a more accurate time, it's likely to be MJ, who can probably do it with her eyes closed.
Thanks both, looks like I've got what I need now
Odd as it may seem, I've never done just a timing belt on a D2. Usually I take the engine & box out and do chain tensioners, oil leaks, and the plastic oil cooler pipe all together.
That said, if everything comes apart ok it should easily be done in a day. The most likely challenges would be seized bumper or front panel bolts - a bumper bolt can take half a day to solve on its own. I'll be doing General Vod's belt and oil cooler pipe with the engine in after Christmas though so I will report back ![]() |
Yes, and no there is no service interval for them. Typically the nylon pads last around 100K, and they're the primary cause of catastrophic engine failure in the D2. I've seen failures from as little as 120k but my Murple is on the originals at 320k so ymmv, literally. At the very latest I would do them with the second timing belt.
Its a good half-day's work with the engine in after the front end and timing gear is off. Allow a day if you're not taking the front end off. Itsa two person job to get the inlet cams back in - one to hold the tensioner and one to slot the cam back in place. These are the nylon pads: https://www.ebay.co.uk/itm/4x-Pad-Ti...K/252466154290 You also need 2x 077198217 which are the gaskets for the tensioners. I recommend removing the little gauze filter from the tensioner when it comes off as that is the primary cause of tensioner failure. Have a read of Big Red's and Stephen's FE WITW threads - there's a chunk more detail on the job in those ![]() |
Also do you have any links to these threads? I cant find anything when searching for their nicks Thank you very much for this you are a never ending source of knowledge for these cars!! Last edited by Ronin; 13th December 2019 at 06:33 PM. |
Stephen's - http://forum.a8parts.co.uk/showthrea...light=workshop Big Red - http://forum.a8parts.co.uk/showthrea...light=workshop There are several other threads in the series as well. Not sure if this will work, but try the following link: http://forum.a8parts.co.uk/search.php?searchid=2872196
I did all of these jobs last year with the engine still in the car. New full Camshaft chain adjuster units. Very expensive for the two, approx £1500 for the two plus £100 for 2 new chains, and that's just for parts. I know that we can just replace the pads but my pads were fine. The adjuster itself on the drivers side was not functioning correctly. It was extremely rettly until the engine warmed up. There is a theory that the detent pin that holds the tensioner in the start position fails and so the tensioner is free to rattle on first startup until engine oil pressure builds up. For me, the rattle was just unacceptable.
The most difficult and frustrating job I did at the same time (with the engine in place) was the plastic oil cooler pipe. Access is really tight. I generally enjoy working on my car but I hope I never have to do that job again. I have no idea of how long the job took though I'm afraid. I never rush my repairs as its a bit of a hobby so I spread it over a few weekends.
