Old 24th January 2020, 01:07 PM
Default Outer window seal replace?
Just a quick one.
How difficult is it to replace the chrome trim strip at the top of the door / bottom of the window? I think it's referd too as the outer chrome window seal. Pop off or do we have to drill rivets?
Thanks Frank
Audi S8 D2 2002 88k mls
Old 24th January 2020, 01:28 PM
Originally Posted by spannerrash View Post
Just a quick one.
Thanks Frank
In the D2 > common faults section there is a Tech Dump with all of the PDFs your heart will ever desire!
Follow this link and there is a section in this document with all the trim removal shown - http://forum.a8parts.co.uk/attachmen...0&d=1420350770
Old 24th January 2020, 02:52 PM
Strip the door down and remove the door frame then the trim knocks off upwards. No rivets. I've not managed to get one off with the frame still in place - I suspect it would take a fair bit of force which would bend the trim.
Old 24th January 2020, 03:16 PM
I've read that pdf previously and just again now but can't find any reference to the trim I am wanting to replace. The chrome strip that runs across the top of the door skin.
Old 24th January 2020, 03:33 PM
Thanks for the replies.
MJ have you ever managed to fit one without stripping the door down? I know that sounds odd but the one on the car is already damaged so I have a spare. Damaging more on removal is no big deal. As long as I don't damage the door itself. But would I be able to fit the replacement without stripping the door?
I may have to buy a complete second hand door to practice on.
Old 24th January 2020, 04:03 PM
I can say (having done it not that long ago to replace the entire window frame) that stripping the door down and taking the frame off isn't actually that difficult. Tedious and takes a little while, and you'll need a few new clips for the door card as some inevitably break.
You just have to be EXTREMELY careful to not lose the tiny little u-shaped plastic insert on the end of the cable from the internal door handle.
(Though I think MJ was possibly 3D-printing some...)
In my case I had to do this to effectively replace one of the nylon pulleys in the window winder mechanism as it had shattered. Replacing the whole frame is much the easiest way, swapping over the glass and motor from the original.
Old 24th January 2020, 04:22 PM
They are just a friction fit on a lip on the top of the sheet metal - exactly the same concept as the door seals. Theoretically yes, you should be able to gently push one on with the door intact. I haven't tried it...
I have bare doors and trim strips on the shelf so I can get pics of specific, but not sure they would be much help.
Old 4th August 2020, 01:40 AM
craig's Avatar
craig craig is offline
Default Remove door trim
It is very hard to do yo will bend them I hot mine off did bend the first one but had spares to play around I managed all mine with patience and care wd40 and plastic trim removal tools the hardest part was separating the strip from the rubber omg that was hard but doable I chromed all mine putting back was hard aswell I could go in depth but look at the results in my album I was well pleased
Old 4th August 2020, 10:35 AM
I can’t find it either
Old 4th August 2020, 12:50 PM
Both of you are correct. The one it does have starts on page 190 which is the chrome roof trim, which is what I initially thought 'at the top of the door' meant.
Just have to use the other D2 authority (MJ) suggestion.
