Old 14th May 2020, 05:19 PM
I just had an idea which I will try later
Ha Ha! I bet it’ll be a bit more high tech than my offering!
Old 14th May 2020, 06:46 PM
HPsauce HPsauce is online now
I bet it involves taking a CAD slice and then 3D printing a single layer.
Then scanning it...….
Old 15th May 2020, 09:49 AM
Trying to output a 3D model to a 2D PDF however, is apparently impossible
Have you tried this method MJ, as I believe you use Fusion 360?
https://knowledge.autodesk.com/suppo...usion-360.html
Old 15th May 2020, 01:40 PM
Ronin Ronin is offline
I know this is a bit low tech, but I took mine out and measured it! Attached are photos with dimensions written on the cover itself (in cm), taken in two different lights, so I hope enough of them are clear to be helpful.
PLEASE NOTE: the photos are rotated 90 degrees relative to the orientation in the car! The 35.5cm line is the bottom of the cover.
Let me know if there's a measurement that's missing.
Thank you so much for taking the time to do this. I will use this for sure.
Old 15th May 2020, 06:22 PM
It’s my pleasure to help other forum members now and then, as it’s been an amazing aid to my various ‘8s ownership over, what must be, getting close to 20 years! I really think that I might have given up on ‘8s if it weren’t for the fabulous people here.
Old 16th May 2020, 07:55 AM
I spent a little time the other day transcribing mine in to CAD. That was easy. Problem is, now all I can do with it is 3d print it or send it to a CNC machine! The idea was to make a 4-page document that you can print, stick together and then cut along the line to make a template. Trying to output a 3D model to a 2D PDF however, is apparently impossible
However, while typing that ^ I just had an idea which I will try later
a cad file like this may still be usefull to for example get it laser cut etc
Old 16th May 2020, 08:21 AM
Hmm laser cutting is a good idea. Could make it out of all sorts of things then - acrylic maybe, or just plywood of course. I might do some investigating
Out of interest what do we think a laser-cut acrylic or plywood replacement panel would be worth?
Old 16th May 2020, 08:43 AM
£20-25 for a nice and thick one?
Old 16th May 2020, 08:52 AM
Thats about what I was thinking too. I shall investigate on Monday
Old 16th May 2020, 10:29 AM
Let me know as soon as you have something.
I've tried making a CAD file to get it laser cut but something isn't adding up with the dimensions provided in earlier posts..
