Old 4th June 2020, 08:13 PM
Does a TMC module automatically mean RNS-D? My murple has the early badge and the different steering wheel (with takata airbag ), and it has a completely different TV tuner to my 2002s, but it did have a TMC module.
How does one tell the difference externally between RNS C and D?
Externally, is tricky.
It is much slower. Also, Where the RNS-D will say A1, M1, the RNS-C just says '1' for example.
It also takes the Travelpilot, rather than Travelpilot DX discs, so that can be a giveaway (although the RNS-D will use either)
Old 4th June 2020, 08:16 PM
I would say yes, as the RNS-C uses the correct protocol to talk to the cluster, same as RNS-E, so no gateway needed.
Dumb question, but its definitely a TMC module behind there, and not one of the old Phone modules that I think used to live there ?
Old 4th June 2020, 08:28 PM
Yes, it was definitely a TMC module. The phone module was down in the centre console
Old 4th June 2020, 09:35 PM
Bit of an odd spec this one:
Autodim mirrors and phone were standard, as was Nav.
It does have Bose and Xenon plus, but no TV. I always found it quite rare to find an S8 with no TV.
Colour is Hibiscus Red, build date 23/03/2000
No towbar, blinds, tv, solar roof, TPM, servotronic, heated rear seats, enhanced leather or heated windscreen.
Nice to see it unmolested really, hope it is mechanically sound, and finds a good home. Don't often see the rare colours.
Old 4th June 2020, 09:38 PM
iirc RNS-C was fitted until early 99, where the 'early facelift' survived until around mid 2000.
I confess, I did think the older style TV tuner was an RNS-C thing, but come to think of it, I've seen way more Tuner A's than I've seen RNS-C's in my time, so I guess not.
Old 5th June 2020, 09:50 AM
The only Hibiscus Red D2 I've ever seen was a guy from Oxford who came to one of our Leamington Spa meets plus one ADI at Castle Combe, I think his name was Alan.
My D2 has RNS C, TV Tuner and had the earlier steering wheel and from memory you have to select the TV as an input rather than having a "TV button" - I swapped in a digibox into the boot early on but the original tv tuner is still there and if i remember correctly had a single input you could plug into for aux rather than having to hard wire in a pair of aux inputs in the RNS Ds ?
Old 5th June 2020, 10:03 AM
Also had Autodim mirrors as standard and a few other things.
Slightly confused by the sellers claim to a leather dashboard.......
Are the autodim mirrors external only, as the internal one is not auto-dimming?
Also, what are 'extended leather seats' that the ad mentions?
Old 5th June 2020, 10:13 AM
Default Indeed
Seem to remember it having an identity crisis
Old 5th June 2020, 10:29 AM
Indeed, I did something similar with mine. The older TV tuner with AUX inputs was quite handy from that perspective.
If you rummage hard enough (I honestly can't be bothered) there's almost certainly a post or two here with pictures of Digital TV on my RNS-C screen.
OK, so I did bother, had a moment of inspiration and found it quickly, you can also see the source button is missing TV, the main external clue to an RNS-C vs RNS-D:
Old 5th June 2020, 12:02 PM
Imaginary, in that one. With whichever leather pack gets the lower door cards, lower dash and tunnel sides, the seat switch panel is also leather. That one doesn't have extended leather or leather dash though. Possibly the seller can't tell the difference between leather and vinyl?
Good spot on the interior mirror. Given that the electronics and light sensors for the auto mirrors are in the interior mirror, it can't only have dimming side mirrors.
