Old 16th July 2020, 08:30 PM
S81 S81 is offline
Default Minor fluid leak power steering cooler ( I think)
I posted this earlier without a title so not sure if it'll appear twice (apologizes if it does) I was checking over car at weekend and found a minor fluid leak at what I think (from reading previous posts) is the power steering cooler, it's located behind the passengers front fog light grill ,if someone could please have a look and suggest what they think the cause is and what the solution might be it would be appreciated
Keith
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 16th July 2020, 11:13 PM
Can't guarantee that this is your problem, but the D3s seemed to suffer from power steering pipes leaking. What I would suggest is first giving the area a good clean and then see if you can locate the exact source of the leak. If it is a pipe, then I'd suggest you check out the following write-up, as I believe it may be the source of your problem:
http://forum.a8parts.co.uk/showthread.php?t=11345
Old 17th July 2020, 07:08 PM
S81 S81 is offline
thanks I cleaned it after the photography and ran the car but couldn't see anything,I dropped her of with the wheel refurb guy this morning ,i'll have a Look when I get her back to see if the run up and down shows anything
Daily driver
Previously owned
