Old 9th December 2020, 12:30 PM
Regarding the aircon drains (the orange ones), check out the following page for a detailed set of instructions, including photos. There are also photos of the drains in the plenum chamber and wheel arch.
http://www.audipages.com/Tech_Articl...tordrains.html
I've also added that link into my previous response above.
Extreme care should be taken with the sunroof drains especially if using an airline in them.
Old 9th December 2020, 12:36 PM
BUT remember the Audipages are for Left Hand drive.
The transmission tunnel trim fixings are NOT exactly mirrored in RHD cars.
And as I think both Sean and I have noted above, it's just as easy to take the orange drain units out completely, clean them thoroughly, trim the ends (optional) and reinsert.
A garage may prefer the air line option though.
Old 10th December 2020, 12:33 PM
Just jumping in here: I found the easiest way to clear the plenum drains was from the side (under the wheel arch) and from below by removing the flexible 'cross cap' and using a drain cleaner: https://www.screwfix.com/p/rothenber...il-1-32m/65766
As for the orange AC drains, I ended up using a hole cutter and cutting out a hole in the tunnel panel adjacent to the drain position for ease of access. I get away with it as the trim is black and you can only see the access point if you crouch down at the door. I also trimmed the ends... seems over-engineered to me.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 10th December 2020, 12:40 PM
Are you sure that wasn't the front aircon drains? Or the little high-level drains under the bonnet near the wings, often just opened up totally.
Old 10th December 2020, 12:49 PM
No, its the big plenum drain. As attached (unless I am getting in a twist). You can get to it through a panel high up under the wheel arch and also from below (with a bit of jiggling). Bear in mind mine is a V6 2.8 motor so maybe it is different with you 'bigger boys'?
Paul
Gosport UK
Honda Jazz
Old 11th December 2020, 12:56 PM
johnny_quattro's Avatar
Here's a photo of the plenum drains, which was taken when my gearbox was 'poorly'. It seems rather popular on Google Photos for some reason.
Name:	Screenshot from 2020-12-11 13-44-02.png
Old 12th December 2020, 10:05 AM
Green Goblin's Avatar
Green Goblin Green Goblin is offline
7. Small drains under bonnet, either side close to the wing panels.
- About two inches long and exit at the back of the wheel arch. Location and image as follows:
Where exactly are these? I just can’t see them
Do I have to remove anything to see them?
I just wanna grab them and pull them out!!
Incidentally, i have the car back and supposedly the drains are all clear now.
But i wanna AT LEAST be able to see where those rubber teats above are because i sure as hell can’t find them...
Old 12th December 2020, 11:09 AM
They are high up in the wheel arch, towards the rear of the arch. If you put the car on full lock and get a decent torch, you’ll see them easily. Unless, of course, they’ve already been removed - but then you can see the hole. No need to remove anything.
Old 12th December 2020, 11:38 AM
If you check the link I provided in post #11 above and search for the term 'Checking the Engine Compartment Drains', the next two photos show exactly where they.
EDIT: Better still, here's the photo:
Old 20th December 2020, 07:39 PM
Audifan Audifan is offline
List of drains and water ingress points (please copy and add/expand/explain):
3. Sunroof drains
- Four in total, one at each corner of sunroof frame. Plastic tubing is very pliable so extreme care when cleaning these out. Front ones exit at the base of the A-pillar (you can see them when you open the door), and the rear ones exit just in front of the back wheel. Illustration of layout as follows:
Who is the idiot that decided it is a good idea to have the front sunroof drains above the door hinge?! For a premium luxury car that was a STUPID idea!
Any tips on clearing out the rear sunroof drains if you don't have shop air to blow the lines clear?
