Old 8th June 2021, 08:10 PM
More cleaning and reassembling tonight
Front panel on tomorrow
ID:	26585   Click image for larger version
Old 9th June 2021, 07:27 PM
Cleaned up and reattached the front panel
Power steering cooler on tomorrow then I can fill it with fluids and start it up
ID:	26587   Click image for larger version
Old 12th June 2021, 09:57 AM
ThisWayUp ThisWayUp is offline
Excellent progress - I need to print this and keep it as my motivational target!
2000 Audi S8 D2 4.2 V8 FL
1997 TVR Cerbera 4.2 V8
1992 Peugeot 205 Gti 1.9
Old 16th June 2021, 10:08 AM
Markiii Markiii is offline
random thought, is the aircon rad on that lump? does it then need a regas?
Old 16th June 2021, 10:43 AM
Yes, its the front bit with the two black pipes to the right. I don't open the AC for this job - I just swing the condenser off to the side. The AC is still nice and cold
Old 16th June 2021, 09:15 PM
Right, I've got very behind on updates in the push to get the car finished, so this is quite a big one!
I checked everything with VCDS before startup and found that the ECU was reporting a MAF error. Changing the MAF didn't help, and it wasn't fuses, so that meant a wiring problem. Pulling back the boot on the connector soon revealed an air gap!
Luckily these terminals fit all sorts of things so I had a spare to hand
Soldered and heat-shrunk since there's no room in there for a crimp. Happy ECU and the engine runs sweetly
Both bumper support bolts were seized so I stripped the bumper down and put the brace bar in the vice then cut the heads off the bolts
Remove these two T25 screws and the 'nut' complete with the stump of the bolt can be removed and the supports are free
Normally I'd try and save the nut, but these will need a lot of work
So I cheated and nicked a pair from a spare bumper
I replaced the lower bumper with the one Strummagnet found for us, and also a parking sensor, and then put it back on the car
I had a slight coolant leak from the one hose I couldn't get new It was just the hose clamp not quite seated properly which was simple to resolve because the SAI rubbish was gone. If that was all still in place this would have been a nightmare to get to!
The air intake on the front panel was broken with all but one of its fixing tabs missing so it just rattled around. Luckily these are still available from Tradition and I have a few sets in stock so this was replaced
The car needed a new windscreen which Mark arranged through insurance. I already had the wiper mech and scuttle panel out but I also removed the windscreen trim ready for the fitters and discovered one of the clips had disintegrated
This is entirely because the factory put some butyl rubber sealant in the bottom of the channel, causing water to pool up around the clip. Why would they do that? I drilled the heads off the rivets and removed the remains of the clip
Then removed the sealant
Cleaned the rusty stains off the paint with fallout remover
I can't get the rivet gun on the rivets with the glass in place
So waited until the glass was out (a 1 hour ordeal for two fitters!) and then rivetted the clip in.
I also rebuilt the wiper linkage using bits from a couple of others (the usual drill) and now there are no good ones left so I am forced to get on with my plan to re-engineer / re-manufacture the mechanisms. I have a cunning plan for that so will provide updates on that separately.
All finished and a clean pass on the MoT
Wheel alignment tomorrow then its all done and ready to go home
ID:	26593   Click image for larger version
ID:	26594   Click image for larger version
ID:	26595   Click image for larger version
ID:	26596   Click image for larger version
ID:	26597   Click image for larger version
ID:	26598   Click image for larger version
ID:	26599   Click image for larger version
ID:	26600   Click image for larger version
ID:	26601   Click image for larger version
ID:	26603   Click image for larger version
ID:	26604   Click image for larger version
ID:	26605   Click image for larger version
ID:	26606   Click image for larger version
ID:	26607   Click image for larger version
ID:	26608   Click image for larger version
ID:	26609   Click image for larger version
ID:	26610   Click image for larger version
Old 17th June 2021, 06:34 AM
Fantastic results, as ever MJ
Car looks fab
How were the windscreen fitters? Must admit I’ve avoided using insurer approved fitters for last 3 windscreens I’ve needed…..
Old 17th June 2021, 07:09 AM
New wiper linkages!! . Can't wait
Old 17th June 2021, 07:31 AM
Car looks fab
This was done by Auto Windscreens and they were really good. They sent two fitters because the screen is so large it's a two-person job to lift it in to place, and that turned out to be invaluable for getting it out too. It was the original screen and the glue was apparently incredibly hard so it took both of them an hour to get it out using every tool they had, but they were very careful with the trim and paint while doing so and didn't damage anything.
As they had, rather optimistically, picked up this job at 4:45 on a Friday afternoon, they were quite grateful that I'd already removed all the trim and so didn't require them to put it back.
I'd made a cardboard template of the position of the glass relative to the body so that we could set it in the right place, since the surrounding trim wasn't going back on at that point, and they were happy to tweak the new glass around so that it matched the template perfectly so everything would go back together.
I think it was 6:30 by the time they left, although they were on overtime by then so not too miffed!
Old 17th June 2021, 09:03 AM
RICKY D's Avatar
RICKY D RICKY D is offline
That is looking might fine now. Great work as usual
