Old 29th May 2022, 02:22 PM
Prefferle Prefferle is offline
Default Knocking front end on rough roads.
Hi folks, can anyone advise how to check the front driveshafts / CV joints for wear tolerances? I’ve had a mysterious knock coming from the front of the car and it’s only getting worse over time. I’ve replaced virtually everything and thinking it must be axles or ??
I’ve got nothing left to replace except the steering rack or front axles however, when I replaced all the inner and outer tie rods the rack shaft and mounting bolts are tight with no play, I even tightened the rack tolerance adjustment which tightened up the steering slightly but there was no steering play anyway…
All front suspension arms, tie rods, steering rack bolts checked, stabiliser bar with drop links replaced, both front air struts - all replaced with NEW parts in an attempt to get rid of this illusive knock. It’s only heard on rough road services and not there at all on smooth roads. The steering is precise and no noticeable play.
As an example It totally sounds Like a loud clunking noise similar to a strut knock or top shock mount knock if it was a typical car.
I’m at my wits end with this car and this issue, any guidance or anyones past experience on something similar is most appreciated.
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
Old 29th May 2022, 03:37 PM
I've read multiple posts from people having this same knocking issue and they seem to have replaced everything to no avail. Two specific things that are mentioned are the ARB bushes and the 42mm inside the front strut.
You mention about replacing the stabiliser bar so that would rule that one out. That leaves the strut itself. The nut in question is under the grommet marked as #4 in the attached image, with the comments being that it may have worked loose. Having replaced everything else, it's worth investigating.
Name:	A8 D3 Front Strut.png
Old 29th May 2022, 03:59 PM
Thanks Steamship, I thought as much initially and sent back the new strut on warranty and they replaced it free of charge, same noise. So with my original old strut, then with the new strut then with another new strut same side same noise.. frustrating to say the least… cheers,
Present cars
Old 30th May 2022, 12:51 AM
mcs's Avatar
mcs mcs is offline
After yesterday's 300klm journey by car also developed a knocking noise when the wheel was turned. I think this unloaded and reloaded the sway bar and therefore the end links.
I am going to investigate this tonight. I have replaced the sway bar bushes, so I will making sure they are in the right spot and havent slipped.
A good idea is to eliminate the sway bar by unbolting it, and taking the car for a drive. If the knock is gone, you have narrowed your items.
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 30th May 2022, 01:58 PM
Hi MCS,
I have replaced the complete ARB / anti-sway bar along with drop links in my quest to finding this noise.
Cheers,
Present cars
Old 30th May 2022, 03:32 PM
We're running out of things to check. Looking at an image of the suspension, you seem to have worked on almost every single nut and bolt. Grasping at straws here, but any likelihood that the bolt (#2 in the attached image) could be loose?
Name:	A8 D3 Driveshaft.png
Old 30th May 2022, 09:26 PM
mcs's Avatar
mcs mcs is offline
Originally Posted by Prefferle View Post
Hi MCS,
Cheers,
In my car, one of those end link bolts in the sway bar keeps loosening over time.
I literally removed the sway bar and the noise went away. I put it back in and retorqued the bolts and it is fine now. I may have to use some thread locker.
Mike
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Reverse Camera
Old 30th May 2022, 10:18 PM
Hey a great point - I’ll be checking that bolt next. What I was thinking was that the axle may be worn and causing that noise. There is no clicking when cornering though which is one sign of a worn axle cv joint… it’s certainly one of the few last possibilities…
Present cars
Old 30th May 2022, 10:20 PM
Mike
Some thread locker would be a good plan however make sure that you are torquing those bolts correctly.
Cheers,
Present cars
Old 31st May 2022, 01:28 AM
mcs's Avatar
mcs mcs is offline
Cheers,
40nm +90degrees
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Reverse Camera
