Old 13th June 2022, 07:17 AM
Ronin Ronin is offline
seeing the slightly conical shape, does it replace the old spring mount on the rear control arm?
Old 13th June 2022, 07:55 AM
Much smaller
Old 13th June 2022, 07:58 AM
Last try:
Some tool to press in the windscreen trim?
Old 13th June 2022, 08:19 AM
sarg sarg is offline
Morning challenge - who knows what this does?
Makes you scream in the morning when you step on it
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 13th June 2022, 08:33 AM
Is it a 3D-printed solution to fixing my abused scuttle cover back in place?
Old 13th June 2022, 08:54 AM
Technically correct
Well done The original is in better condition than the replacement, barring this centre support, so I'm going to repair it rather than replace. This printed part is bonded on underneath in place of the chunk which is missing (using methacrylate structural adhesive), and will function the same as the original
Old 13th June 2022, 08:58 AM
Excellent stuff! Insider knowledge helps here obviously.
Old 15th June 2022, 06:51 PM
I put all the rear suspension back together and forgot to take any more pictures, but its much the same as the stuff I already showed.
The front headlight level arm was seized, and the rear wasn't far behind so I made a new pair:
Turned a couple of bushings for the front C-links on the lathe - the links now sit vertically when the car is on the ground, the same as the A4 links did on the FE. This should make the links last much longer
This is the printed repair piece bonded to the scuttle trim
Fits perfectly
That's all the mechanical stuff finished so off for a wheel alignment in the morning, and then on to the last few bits in the interior
ID:	28664   Click image for larger version
ID:	28665   Click image for larger version
ID:	28666   Click image for larger version
ID:	28667   Click image for larger version
Old 15th June 2022, 07:31 PM
Fits perfectly
Of course it does.
Old 15th June 2022, 07:32 PM
Ahhh! so thats what it was
