#111
seeing the slightly conical shape, does it replace the old spring mount on the rear control arm?
#112
Much smaller
#113
Last try:
Some tool to press in the windscreen trim? |
#114
Makes you scream in the morning when you step on it
#115
Is it a 3D-printed solution to fixing my abused scuttle cover back in place?
#116
Technically correct
#117
Excellent stuff!
#118
I put all the rear suspension back together and forgot to take any more pictures, but its much the same as the stuff I already showed.
The front headlight level arm was seized, and the rear wasn't far behind so I made a new pair: Turned a couple of bushings for the front C-links on the lathe - the links now sit vertically when the car is on the ground, the same as the A4 links did on the FE. This should make the links last much longer ![]() This is the printed repair piece bonded to the scuttle trim Fits perfectly ![]() That's all the mechanical stuff finished so off for a wheel alignment in the morning, and then on to the last few bits in the interior ![]() |
#119
#120
Ahhh! so thats what it was
