Old 7th November 2022, 08:39 PM
Back on this one after an extended hiatus as I need it finished and sold, and I'm fed up of moving it out of the way!
The engine is ready to go back in
The engine bay is ready for the engine to go back in
So I put it back in.
I think this car deserves one of the last ever genuine air filters
As the belt covers and manifold are powdercoated, I did the snub mount as well.
Nice and smart
Much of the running gear is steel on the PF and so very rusty. This will not do Stripped the calipers completely
Printed a bunch of blanking plugs
Bits and bobs
Pistons - the front ones are fine, the rears are toast
Crusty rear hubs
Pushing the ABS sensors out
Front hubs prepped as well
All ready to go for blasting
Blasted and clean
and painted
Calipers too
Sitting in the office to dry for a week
ID:	28919   Click image for larger version
ID:	28920   Click image for larger version
ID:	28921   Click image for larger version
ID:	28922   Click image for larger version
ID:	28923   Click image for larger version
ID:	28924   Click image for larger version
ID:	28925   Click image for larger version
ID:	28926   Click image for larger version
ID:	28927   Click image for larger version
ID:	28929   Click image for larger version
ID:	28930   Click image for larger version
ID:	28931   Click image for larger version
ID:	28932   Click image for larger version
ID:	28933   Click image for larger version
ID:	28934   Click image for larger version
ID:	28935   Click image for larger version
ID:	28936   Click image for larger version
ID:	28937   Click image for larger version
ID:	28939   Click image for larger version
Old 7th November 2022, 08:48 PM
New seals and rear pistons from Bigg Red
Carriers rebuilt with new boots and bolts
Rear caliper with a new piston
Back together
As these are steel calipers I can use stainless bleed screws, and also genuine Brembo cover caps for added longevity
Complete with new hose
Front caliper
Pistons and slider boots back in. I forgot to get a pic of it complete.
Rear hubs are looking considerably nicer, and have new bushes fitted
Front hubs back on the car
ID:	28941   Click image for larger version
ID:	28942   Click image for larger version
ID:	28943   Click image for larger version
ID:	28944   Click image for larger version
ID:	28945   Click image for larger version
ID:	28946   Click image for larger version
ID:	28947   Click image for larger version
ID:	28948   Click image for larger version
ID:	28949   Click image for larger version
ID:	28951   Click image for larger version
Old 7th November 2022, 10:45 PM
Nice and smart
And then some.
A tool for every occasion. Just how many A8 specific tools have you made over the years?
Old 8th November 2022, 07:48 AM
Enough to have a 'special tools' drawer in the toolbox
Old 8th November 2022, 08:44 AM
Attention to detail as ever MJ Almost too smart to drive about in now!
Old 8th November 2022, 01:42 PM
Painted uprights
The shocks getting a little paint as well?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 8th November 2022, 04:18 PM
Ronin Ronin is offline
Why are the rear caliper pistons push things threaded? This gave me an idea to install autohold from D3 now
Old 8th November 2022, 04:33 PM
Painted uprights
They are making me sad for sure. I may just put new ones on it.
Old 8th November 2022, 04:36 PM
Its part of the handbrake mechanism. The lever pushes the threaded rod forwards which provides the clamping force, but the thread allows the piston to move hydraulically too and more importantly adjust itself as the pads wear.
I looked in to fitting D3 calipers to get larger rear brakes without the shenanigans of LWB handbrake cables, but I'm suitably convinced the electric calipers are more trouble than they are worth.
Old 15th November 2022, 07:03 PM
Subframe off for refurb.
I couldn't help myself and cleaned the floorpan
ID:	28986   Click image for larger version
ID:	28987   Click image for larger version
ID:	28988   Click image for larger version
ID:	28989   Click image for larger version
ID:	28990   Click image for larger version
