Old 31st May 2024, 09:43 PM
dsasa dsasa is offline
Default water Cooler Hose
Does anyone has this hose for Sale. Need urgently !!!!!Click image for larger version
Old 1st June 2024, 12:27 PM
sarg sarg is offline
I don't have anything for sale, but even if I did, you need to give a bit more detail, a part number ideally, but at least some clues as to what car/engine its come from and its function
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 1st June 2024, 03:34 PM
This was also posted on one of the Facebook Audi groups, and I'm sure I responded to it either with the part number, or asking for more details of the engine.
EDIT: I did respond to it, but it wasn't on Facebook. It was here in the following thread, and I replied on the 23rd May with the part number and also the phone number for A8parts. I knew I had seen that photo before.
https://forum.a8parts.co.uk/showthread.php?t=17241
Old 2nd June 2024, 11:59 AM
Spanker's Avatar
Spanker Spanker is offline
If you're looking for a hose that's exclusively for a D2 3.3TDi then unfortunately you may be out of luck on a UK forum (the 3.3TDi not being a model released in the UK).
But until you inform the group of the part number or location of the hose then it's unlikely that anyone can help.
I could see on the image that you supplied that there was a print of the Audi rings in white. Did the part number that's printed next to the rings survive the test of time?
Dean
Old 2nd June 2024, 01:28 PM
Oddly enough, I provided both a screenshot of the possible pipe (for them to verify) and a part number, but instead of replying in that thread, they started another post!
Old 2nd June 2024, 02:20 PM
Spanker's Avatar
I did see that and I did do a search to see if the part number you mentioned was readily available here in Germany. And it wasn't. I don't think the OP is going to get very far unless more info is given.
Dean
Old 2nd June 2024, 03:00 PM
Best I could find was one site that had 'Request a quote' as opposed to the usual 'not found'.
