Old 1st October 2013, 04:14 PM
Default Identified my Blown Fuse Problem
One of the minor issues I've had since getting the A8 is that it was continuously blowing the fuse for all the interior lights. I also noticed that when this happened, I didn't get the indicator flash when locking or unlocking the car. The alarm horn didn't work either.
After scouring the forum, there was a comment about the batteries in the alarm horn causing corrosion, so with Saturday being a good day and me being reasonably okay, I set about trying to locate the alarm horn, and this is what I found:
Two of the pins heavily corroded and part of the plastic missing:
Front and back views of the circuit board:
With this removed, I replaced the 10A fuse, and so far, everything is fine. If I'm up to it, a trip to the scrapyard tomorrow and hopefully I can pick up the alarm and maybe part of the loom.
Old 1st October 2013, 10:07 PM
Excuse my ignorance, but where that alarm circuit is board is located in the car?
Old 1st October 2013, 11:48 PM
The alarm horn is located behind the trim in the left side of the boot behind the CD changer. Didn't know where it was myself until I started searching for it, in all honesty. It's amazing what other electrical gizmos are lurking in there as well. Since the alarm was knackered anyway, I decided to pull it apart to see how much damage the leaking batteries caused.
Was thinking of doing a writeup on it for the forum, once I get a replacement, since it appears to be a common issue.
Old 2nd October 2013, 07:01 AM
Wow - what a mess! Looking forard to write up and then I'll check mine.
Glad you got problem identified.
