It appears to be attached to the throttle body by two screws. The best picture of it I could get was here:
http://www.audiforums.com/forum/audi...5/#post1082894 Not sure how easy that will be, as no way to guage 'actual' position.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! ![]() My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 8th December 2014 at 06:06 PM. Reason: photo link |
Well, by the time I left work, the ESP had gone off and the power was back to normal. The ABS, EMS and another (yellow triangle) light were still on though.
I called in to A4 Audi and got a diagnostic scan. It was the throttle position sensor and Andy cleared the other lights, which have stayed off. He thinks that it's water getting into the switch/connector above the throttle peddle and, if I search my ageing memory, I seem to recall the same issue a couple of years ago. I'll need to get a closer look when I find the time.
So that's the pedal position sensor, not the throttle body sensor?
Yes, I think so
Z
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
That's what I'm beginning to suspect on mine, how easy to fit and how much are they?
After fitting, you then need to adjust it, and will need VCDS to do it. I've attached an image of the culprit and also the adjustment instructions. The one on mine has the part number 028 907 475 BD ('01 3.7), diesel ones are BC, but can't confirm if all the petrol ones use the same part. Used one on eBay range from £46 (from A8parts) upwards.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! ![]() My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 9th December 2014 at 11:59 AM. Reason: location of part |
Thanks, A8parts show the one they have (BD) as being compatible with a long list including S8.
I'll plug in VCDS and check the measuring blocks. I "thought" I'd done it before but I suspect I did the throttle body not the pedal. ![]()
Update on mine:
Car ran fine from Monday evening, through absolutely torrential rain and sleet on Tuesday and Wednesday and then, towards the end of my commute this morning, which wasn't that wet (and after sitting in my garage all night) same fault. ABS, EPC and ESP lights on and no 'oomph'. So, my current thinking is that it's not water ingress, but more likely the increasingly frequent, intermiitent fault on the sensor that Zip describes. Planning to book it in to have this, cambelt (and ancillaries), brake fluid change and headlight washer done. Gonna set myself up as a registered charity and/or remortgage the house and/or sell the kids into slavery! ![]()
I was plagued with the very same problem recently. It took me months to sort it and as always I looked at the most expensive items first. I changed practically everything including the throttle position sensor and the throttle body. It turned out to be the fuel pressure regulator and a broken wire in the throttle body cable. The solution is sometimes not the most obvious.
2001 D2 S8. Volcano black. KW Variant 1 coilovers. EBC Turbo grooved discs with Yellow Stuff pads. 19 inch R8 replica wheels with 255/35/19 Michelin Super Sport. In the UK, 1990 Audi 90 2.3 20v Quattro with just 65,000 on the clock and in mint condition. |
