Old 11th December 2014, 09:47 AM
Default Timing belt kit
I need to get this sorted soon and, according to one local Audi Indy, Audi don't do a kit which includes the water pump and thermostat. And they're quoting £389 for the belt, rollers and guides (fitted, inclusive) plus £171 for the pump plus £556 for the thermostat (with housing). That can't be right, can it?
What kit do you guys use?
Old 11th December 2014, 10:18 AM
Seriously? That's more than what it cost me to get the entire job done. Admittedly, I tend to buy what I can afford, but the parts cost me £345 and the mechanic charged £160.
Old 11th December 2014, 10:20 AM
Price for belt, rollers and guides including fitting is not bad, does it include damper as well, they are around £150 from the dealer on their own? Water pump with seal should be £113, funnily enough pump on it's own without a seal is a lot more expensive. Thermostat is £26, there is no housing as such but cover is £72 but it does not need replacing. Also might as well replace v-bet with rollers as well while they are off.
Old 11th December 2014, 11:20 AM
SilverS8 SilverS8 is offline
Check mister-auto.co.uk
In the norwegian site i use (mister-auto.no) they have a Contitech Timing belt kit with damper,roller and guides for GBP 179 (currency converted)
But i could not find it on the UK site for some reason but the must have it..
They also have the waterpump at GBP 68 and thermostat at GBP 20
Aaah.. see now that your prices was including fitting..
Well
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 11th December 2014, 11:45 AM
Does anyone have the ability and inclination to list the parts, part numbers and prices (Audi) that I should be looking at for a 'thorough' job? Not sure what the 'V belt' is.
Old 11th December 2014, 01:29 PM
Poly v belt is the accessory belt (what us older folk would've called a fan belt when that's all it drove) so on our cars drives power steering, water pump (iirc), air conditioning
Old 11th December 2014, 01:33 PM
Ah, I've just had a new fan belt, so I'll give that a miss. Thanks
Old 11th December 2014, 03:47 PM
Dave McB Dave McB is offline
I got all the timing stuff done on my car last year (o.e INA stuff) and im pretty sure, although the belt was only about 20-30 quid, that the tensioners were ruinously expensive - and that's at COST price.
So £150 sounds decent for the belt kit
Bear in ind the whole front end has to be removed to do the job properly. Its down as a labour time of around 10hrs IIRC
The water pump was about £80 quid for the OE spec one I bought - The thermostat housing may be an OE item with your local audi specialist making a mark up on it from there tho. I suggest pricing it yourself.
Old 12th December 2014, 01:12 AM
mikes2 mikes2 is offline
i paid £624 all in for the 3.7.
Complete timing belt kit plus thermostat and all belts.
2002 3.7 quattro sport (SOLD)
Old 12th December 2014, 06:24 AM
Belt 078 109 119 J £81.32
Idler pulleys x2 077 109 244 C £95.99 each
Idler Pulley 077 109 244 E £76.14
Damper up to chassis no 4D-Y-016 500, 059 109 479 B £147.77 from chassis no 4D-Y-016 501, 077 109 479 D £147.77
Water pump with seal 077 121 004 PX £113.11
Thermostat 077 121 113 D £26.27
O-ring for thermostat N 901 368 02 £4.90
Audi also say camshaft sprocket bolts need to be replaced x2 N 906 371 01 £4.86 each
