Old 3rd August 2016, 06:26 PM
Default Odometer 'FUSE'
Just curious what this means or refers to ...
It appeared after scanning for fault codes using my ODBeleven device.
I rescanned for fault codes after it appeared but no faults were found, before or after.
Pressing the trip reset button cleared it and it never came back (this was several days and hundreds of miles ago).
Old 3rd August 2016, 08:34 PM
Mark, I've seen something similar on other Audis. The solution for them was a blown fuse relating to the dash, there being two fuses.
Old 4th August 2016, 07:20 AM
Ah, thanks
I suspect it must've been a glitch caused by the fault code scan in that case; I'm pretty sure there are no blown fuses. Nothing has stopped working as it should, there are no fault codes and the 'FUSE' error message hasn't returned since.
