Old 29th October 2016, 07:23 PM
North2007 North2007 is offline
trim.A3B20A0A-D6BC-4A96-B677-5837D2FF5086.MOV
Video of starting attemp
2003, A8 D3 4.0 TDI
Old 29th October 2016, 07:41 PM
Originally Posted by North2007 View Post
Lee, all codes cleared. Subframe and rack remained in place, only cooling and alternator removed. New battery doesn't seem to have a code, I'll return for a batttery with a BEM code, before coding. That's for your advice.
I'm sure I've read somewhere on the forum about recoding a new battery, even if it doesn't have one. Will need to do a search to see if I can find it.
ADDENDUM: That didn't take too long. Not exactly what I said it was about, but worth a try. The link is as follows:
http://forum.a8parts.co.uk/showpost....84&postcount=4 and the line in particular was:
'Just go into the battery coding and change the end digit to +1 from where it is and you'll probably find all is well again for a long while '
Worth a try, and may save you having to taking it back to the shop.
Last edited by steamship; 29th October 2016 at 07:44 PM. Reason: Link to other thread
Old 29th October 2016, 09:27 PM
47p2's Avatar
47p2 47p2 is offline
Silly question from me but is the new battery fully charged?
Nite Blue 3.0L SE Quattro
Old 30th October 2016, 05:14 PM
Coded the battery, attempted to start. Listened to the start click a few times. I had removed the strap and replaced it before tightening up. I removed the strap and filed the innner washer, chassis plate and bolt, to ensure a good connection. Firer up first time ������. Many thanks for all your help. Attached photo of strap
2003, A8 D3 4.0 TDI
Old 30th October 2016, 07:45 PM
47p2's Avatar
Did you have that earth strap off when doing the turbo?
Old 30th October 2016, 08:44 PM
Earth strap was removed, then secured back on, it was tight! However would not conduct well enough to turn starter. Only after a file back did it work.
2003, A8 D3 4.0 TDI
Old 30th October 2016, 10:06 PM
47p2's Avatar
So where exactly is it?
Old 30th October 2016, 11:05 PM
Right when arch, photo shows side of strut - just to right of it 13mm bolt securing
2003, A8 D3 4.0 TDI
Old 31st October 2016, 05:53 AM
47p2's Avatar
That will be under the wheel arch liner then?
Old 31st October 2016, 07:15 AM
Yes
2003, A8 D3 4.0 TDI
