Old 14th April 2017, 07:06 PM
david david is offline
Default advice please on gear shifter removal
Got a new auto gear shifter coming from prestige as the button on my D2 one wont come back out when pressed. fed up prising it out with a screwdriver!! Struggling to work out how to remove the broken one however.
2002 a8 d2 2.8 sport silver
2002 a8 d2 2.8 sport metallic blue
Old 14th April 2017, 07:40 PM
Haven't read these instructions, but I think this is what you want to know:
http://www.audipages.com/Tech_Articl...erremoval.html
Old 14th April 2017, 07:46 PM
Do you mean the whole shifter mechanism? Thats a fairly big task iirc. To get the wood surround off you need to remove the two console side panels and there is an M6 socket head screw on each side holding the wood piece in. I'll have a look in Elsawin and see if there's a procedure for swapping the unit over.
Old 14th April 2017, 08:31 PM
Its only the top part of the shifter i need to remove and I was really hoping it can be done without removing the side panels. Haven't seen any screws that would help it be this easy tho.
Old 14th April 2017, 11:01 PM
Sorry, thought you meant the whole thing. Check this video out:
https://www.youtube.com/watch?v=aiQ4BeWaNAM
I can't check my own car out, as it's still with the mechanic.
Old 15th April 2017, 08:16 AM
https://youtu.be/uXyEEWQ1LCQ
https://youtu.be/JQGstkay2Tg
Old 15th April 2017, 08:36 AM
I can't help but notice that clarity it being sacrificed in this thread in an attempt to avoid double entendres.
Say it like it is, you want to know how to pull your knob off!
Never had mine apart but, looking at the videos, there doesn't seem to be a lot to go wrong in there. Maybe a little lube is all that's needed (no double entendre intended)?
Old 15th April 2017, 01:23 PM
Default Sorted
Many thanks everyone, job done in 5 mins. A little knowledge is a wonderful thing.
