fitted all in everything working ok but says acc not available
plugged in vcds coming up code 01517 control module for trailer/towing sensor rechecked all recoding but cant do anything with abs any body had this issue is there something ive missed ![]() |
Can you post a full VCDS scan so we can look at it all.
Del ![]() |
thankyou for reply ive been studying your retrofit brilliant write up. I run my vcds on diag laptop only never worked out how you post pics on forums
Del ![]() |
When you have done the scan you can click on "Save Scan". This will save a text file in the "Logs" folder under "RossTech" folder on the PC.
This text file can be opened in "Notebook" and played with.You can copy the relevant bits and paste them into your message to the forum. Hope that is clear enough.
So far as trying to figure out what is really wrong, what you need to do now is go back into VCDS and clear all the faults. Drive the car for a day or two and then rescan. This helps to eliminate any faults that have been thrown up because of something like a low battery (I did notice a line showing a voltage of 8.7) and should hopefully just leave the current faults. Once you've scanned it again, post the log up here again.
Coding is wrong in module 0x13
is that the abs module? could not do anything with that coding wise unless I'm doing it wrong
had another go this morning found a code on google for acc but still no luck nothing I do seems to work
![]() so that's it for me now 500 down the drain again don't even know if gateway is right 4e0907468b |
