Old 28th September 2017, 10:05 PM
karlcossy karlcossy is offline
Default fitting acc 01517 code ??
fitted all in everything working ok but says acc not available
plugged in vcds coming up code 01517 control module for trailer/towing sensor
rechecked all recoding but cant do anything with abs
any body had this issue is there something ive missed
Old 29th September 2017, 04:33 AM
Can you post a full VCDS scan so we can look at it all.
Old 29th September 2017, 09:09 AM
thankyou for reply ive been studying your retrofit brilliant write up. I run my vcds on diag laptop only never worked out how you post pics on forums
Old 29th September 2017, 10:16 AM
Its all in here.
A full scan will be useful if you can share it here. Paste the text not a picture.
Old 29th September 2017, 05:54 PM
When you have done the scan you can click on "Save Scan". This will save a text file in the "Logs" folder under "RossTech" folder on the PC.
This text file can be opened in "Notebook" and played with.You can copy the relevant bits and paste them into your message to the forum.
Hope that is clear enough.
Old 29th September 2017, 06:42 PM
ok thankyou I will give it a go and try not to get to stressed
Old 29th September 2017, 08:03 PM
Originally Posted by karlcossy View Post
wow I did it
load of faults there to be going with for me apart from the stupid cp that needs doing somehow lol
Firstly, not as many faults as you think. It appears that you ran three scans today, and it appended the output into the one file.
So far as trying to figure out what is really wrong, what you need to do now is go back into VCDS and clear all the faults. Drive the car for a day or two and then rescan. This helps to eliminate any faults that have been thrown up because of something like a low battery (I did notice a line showing a voltage of 8.7) and should hopefully just leave the current faults.
Once you've scanned it again, post the log up here again.
Old 29th September 2017, 08:28 PM
Coding is wrong in module 0x13
Matt
Old 29th September 2017, 09:35 PM
is that the abs module? could not do anything with that coding wise unless I'm doing it wrong
Old 30th September 2017, 10:31 AM
had another go this morning found a code on google for acc but still no luck nothing I do seems to work
so that's it for me now 500 down the drain again
don't even know if gateway is right 4e0907468b
